looking for coilover setup
09-25-2012, 04:25 AM | #1 |
113
Rep 739
I have an e92 with m3 suspension bits in the front and soon to have subframe bushings and sway bar in the back. I am looking to get coilovers with camber plates. My budget for these 2 combined is right around 4k. I have a couple options i am looking at but am open to more opinions. Currently im looking at JRZ, Ohlins, Nitron, and Bilstein.
09-25-2012, 08:17 AM | #2 |
2006 330i, TSM, Black, manual, sport
878
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
What are you planning to do with the car? Track it? Street driven only?
Bilstein would be fine for street driving. KW series 1-3 would be good too. If you're going to track your car, you may want to add AST to your list as well. I've riden/driven in cars with both AST and JRZ (turugara and CJ421). I know the JRZ setup works VERY well, but I prefer the AST feel vs. JRZ. JRZ allows more body roll (rolls, then takes a set and stays there), but the AST is setup very similar to my JIC-Cross where there is no real body roll. Just my preference. Both cars also have the M3 suspension bits. I'm sure CJ421 will chime in. I think you also need to change to M3 rear control arms as well. I'd definitely recommend my JIC-Cross coil-overs if they hadn't gone out of business! I also have UUC adjustable swaybars. I figured if I'm going to get swaybars, why not get the ones that are adjustable. Nitron is also a very good shock for a decent price. They may have to play with spring rates as I'm not sure anyone has a setup on a 335 yet. I only know of VAC having them on their e92 M3.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
09-25-2012, 09:51 AM | #3 |
113
Rep 739
The car is my daily driver but ive always enjoyed a stiffer feeling car. The end goal of these suspension mods is to make my car into a car that i can dd and bring out to a track multiple times a year as well as just help spirited driving in general. So i want something that i can dd on a bit less camber and a relatively soft ride and then change some rebound and/or dampening rates as well as camber and head to the track.
Ive looked at asts and they seem like a good option but ive heard they tend to blow out and need to be rebuilt often? |
09-25-2012, 01:09 PM | #4 |
1559
Rep 4,109
Drives: BMW M3
I have a JRZ damper setup as Rob said. They were a good bit of money but were worth the investment for me. I take my car to road course HPDEs often. If that is not the case then I think you could get away with something less expensive and still achieve the 'quicker' handling you're looking for.
My suggestion, look at a TC Kline setup. They are custom valved Konis and well priced: http://store.vacmotorsports.com/tc-k...kits-c327.aspx You'll be able to end up with a far better handling car than stock in all conditions with that setup + a good alignment. Of course this is assuming you have good tires ... do you?
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
09-25-2012, 03:27 PM | #5 | |
91
Rep 1,324
Drives: 335i Coupe, 6 Speed
They are a new entry into the BMW suspension world and rumor has it they may be the best bang for your buck damper out there in the price range you mentioned. |
09-25-2012, 03:44 PM | #6 |
878
Rep 3,699
Thanks guys!
09-25-2012, 04:58 PM | #7 |
113
Rep 739
I am running 18x8.5 fronts 18x9.5 rear 245/40 front 275/35 rear toyo r888's.
Is there any coilover out there that really jumps out as better than the competition? I drive my car relatively hard everyday and i want it to perform when i want it to, but i do also attend track days in the area about once a month. |
09-25-2012, 09:32 PM | #8 |
91
Rep 1,324
I can personally say that with the AST 5200's, full soft feels very comfortable while full hard is still not harsh, yet significantly tighter. The JRZ'S, as Charles will attest to, are similar in that regard. Given your budget range and choice of brands, you really can't go wrong. Add Moton to your list while your at it.
09-26-2012, 08:18 AM | #9 |
878
Rep 3,699
Something to consider:
http://store.bimmerworld.com/closeou...n-m-p1333.aspx
09-26-2012, 10:39 AM | #10 | |
1559
Rep 4,109
Drives: BMW M3
09-27-2012, 09:30 AM | #13 | |
878
Rep 3,699
09-27-2012, 05:40 PM | #14 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
