19x9.5 offset 24
07-27-2007, 04:22 PM | #1 |
12
Rep 294
19x9.5 offset 24
19x9.5 et24. Will this size wheel rub in the rear? I have stock suspension at the moment, but I will most likely drop it another half inch or so (eibach pro kit, or h&r sport with koni yellows).
Any input from experience would be helpful. |
07-27-2007, 04:42 PM | #4 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
I have 19 x 9.5 ET 25 (well 40 but with 15mm spacers to give me 25) and it rubs. I'm on eibach pro-kit and this is for a sedan. For the coupe it might be even a bigger of a problem.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
07-27-2007, 04:46 PM | #6 |
Moderator
318
Rep 17,767
I'm on 265/30/19 at the rear..forgot about that.
07-27-2007, 04:51 PM | #7 |
BimmerPost Supporting Vendor
2042
Rep 25,989
We've had customers try to fit 19x9.5 et 22 in the rear of E92 and they ran into rubbing issues. Our recommended tire size for that wheel is a 265, and those who tried the +22, also tried going to smaller tire sizing (255's, even 245's) and they still ran into rubbing issues.
A +24 offset won't stick out as much as a +22 (its only a 2mm difference, but still), but you probably won't be able to run as large a tire as you'd like. Upon lowering it, its only going to exacerbate the problem.
VMR|Wheels | 714.442.7916 |
07-27-2007, 04:57 PM | #8 |
Rep 31
Drives: 2006 black e90 330xi
et22 rubbing
I have 265 30 19 with et25, no rubbing. I have an xi sedan but they will not rub on an "i" either. If you do lower the car then they will definitely rub.
07-27-2007, 11:19 PM | #11 |
113
Rep 2,889
Drives: 11' E93 M3 LMB
I have 19x10 et22
lowered with H&R sport springs after rolled mt fender and get some narrower tires(from GOODYEAR F1 to Falken FK 452) same 265s but Falken actually a little bit narrower that GOODYEAR my rubbing issue is almost 100% gone
11' LMB E93///M3 KW V3 / 19" BBS LM DB-SLD 20th limited edition / AP Racing Pro 5000+ BBK / Akrapovic Evolution Line Exhaust / Arkym Rear Diffuser /Dinan Stage 2 Engine Transmission software |
07-28-2007, 03:05 PM | #13 |
General
1569
Rep 29,202
What?! You change the 275/30 for 285/30
07-29-2007, 06:25 PM | #14 |
1439
Rep 1,614
Roll the fenders and it should be fine. We have done 19x9.5 ET22 with 265. It also depends on the tires.
For the E90 335, there is more room than the 325/330 |
08-06-2007, 06:30 PM | #15 |
12
Rep 294
bumper. They really need to step up and make some wheels with the right offset for the e92. By "they" I mean schnitzer, rd sport, etc, etc.
08-06-2007, 06:33 PM | #16 |
The 3 Day Diet!
19
Rep 630
Drives: Space Gray e92, 88 911 Cab
you'll rub with a few folks in the car over bumps. I have a 33 et with the same wheel size and lowered on sport springs. I only rub under severe bumps with passengers.
2007 BMW 335i coupe, Step w/ Procede, Aero Lip, H&R Sport Springs, M6 reps, Toyo T1R 235/275's
1988 Porsche 911 Cab, 47k, SW chip, cat pipe, M&K exhaust. |
08-06-2007, 06:38 PM | #17 |
580
Rep 3,547
Roll your fenders and add a little more neg camber. You'll be fine with the 265s .. its all a matter of what you want ... the more agressive offset (lower offset) will give you a more flush look then a higher offset.
08-07-2007, 08:14 AM | #18 |
12
Rep 286
Maybe you guys can help me out here too.
I am looking at a new wheel set up for my e92. F:19x8.5 +47(-15 with Spacer and long studs)= +32, 245/35/19 R: 19x9.5 +27 , 275/30/19 Will this set up work? I am not going to touch the suspension at all.
'07 335i Coupe. Sapphire Black, Coral Red, Brushed Aluminum. ZSP/ZPP/ZCW. 6MT.
30% Tint. OEM Front Aero Kit. OEM Aluminum Pedals. M3 Short Shifter. 19" V715's. |
08-07-2007, 12:45 PM | #19 |
38
Rep 853
I have that exact same setup for the front and do not rub at all. The rears will have a slight rub. Go with a 265 rear tire and roll the fenders and problem solved.
2008 SG E60 535i 2006 AW E90 325i |
08-09-2007, 11:00 PM | #20 |
Rep 209
I'm thinking about wheels right now, CSL Reps or the 715s, I really want the most aggressive offset without issue, is the +22 just too much for the E90? How would the +30 look?
08-20-2007, 03:37 PM | #21 |
Deuce
16
Rep 245
i put a set of 19 x 10.5 (rear) on my gf's e90 +21 lowered on coilovers- you have to run a 245 stretched tire to make it work. I didn't roll the fender either and it was super aggressive but fit. extreme flush look!
i have 20"x10 +33 on the rear now- and it tucks really nice, but you can go +30 and i think it would look great. As you may know, you have to take the tire size into consideration- i'm running the same 245's on the rear as I did with the 19's. |
08-20-2007, 03:45 PM | #22 | |
580
Rep 3,547
