ask RFT indicator
07-27-2007, 03:20 AM | #1 |
HONG
Rep 22
ask RFT indicator
I want to ask how does the rft indicator work? When i let my one tyre without pressure and i drive my car in high speed my rft idicator didn't warning me? do anyone ever try this? :mad:
07-28-2007, 11:39 AM | #3 |
52
Rep 1,349
Drives: 330i
YOu first need setup RFTI.
'06 330i Monaco Blue/Gray/Walnut/ZPP/Navi/CA/AT -->ED 2006
'18 330i Estoril Blue Metallic/cognac/AT/Sport |
08-03-2007, 10:41 PM | #5 |
52
Rep 1,349
Drives: 330i
RTFM page 88
Flat Tire Monitor FTM The concept The Flat Tire Monitor monitors tire pressures while the car is being driven. The system reports any significant loss of pressure in one tire in relation to another. If a tire loses pressure, its rolling radius changes, and this in turn alters the speed of rotation. This change is detected and is reported as a flat tire. Functional requirement In order to assure the reliable reporting of a flat tire, the system must be initialized for the correct tire inflation pressure. The system must be reinitialized each time a tire inflation pressure has been corrected or a wheel or tire has been changed.< System limitations The Flat Tire Monitor is unable to warn the driver of sudden, severe tire damage caused by external factors, nor can it identify the gradual loss of pressure that will inevitably occur in all four tires over a lengthy period of time.< In the following situations, the system could be delayed or malfunction: > System has not been initialized > Driving on snowy or slippery road surface > Performance-oriented style of driving: slip in the drive wheels, high lateral acceleration > If snow chains are attached Initializing the system The initialization is completed during driving, which can be interrupted at any time. When driving resumes, the initialization is continued automatically. Do not initialize the system while snow chains are attached.< iDrive concept, refer to page 16. 1. Press the button. This opens the start menu. 2. Press the controller to open the menu. 3. Select "Vehicle settings" and press the controller. 4. If necessary, move the highlight marker to the uppermost field. Turn the controller until "FTM" is selected and press the controller. 5. Start the engine, but do not start driving. 6. Select "Set tire pressure" and press the controller. 7. Select "Yes" and press the controller. 8. Start to drive. "Status: FTM active" reappears in the Control Display. Initialization is then completed while the car is in motion. Indication of a flat tire The warning lamps come on in yellow and red. A message appears on the Control Display. In addition, an acoustic signal sounds. There is a flat tire or substantial loss of tire pressure. 1. Cautiously reduce speed to below 50 mph or 80 km/h. Avoid sudden braking and steering maneuvers. Do not exceed a speed of 50 mph or 80 km/h. If the car is not equipped with Run- Flat Tires, refer to page 196, the standard equipment by design, do not continue driving. Otherwise a severe accident could result after a tire puncture.< 2. At the next opportunity, check the air pressure in all four tires. If all four tires are inflated to the correct pressures, the Flat Tire Monitor might not have been initialized. The system must then be initialized.< 3. In the event of complete tire pressure loss, 0 psi/0 kPa, you can estimate the possible distance for continued driving on the basis of the following guidelines: > With a light load: 1 to 2 persons without luggage: approx. 155 miles/250 km > With a medium load: 2 persons, luggage compartment full, or 4 persons without luggage: approx. 90 miles/150 km > With a full load: 4 or more persons, luggage compartment full: approx. 30 miles/50 km Drive cautiously and do not exceed a speed of 50 mph or 80 km/h. In the event of pressure loss, vehicle handling changes. This includes reduced tracking stability in braking, extended braking distance and altered natural steering characteristics.
