Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Tire Mounting Tool
      07-26-2007, 05:44 PM   #1
bg
Drives: BMW X3
Tire Mounting Tool
I read somewhere that BMW markets a simple tool that helps lift the tire off the ground and helps align the holes so that the lugs can be easily screwed in.
I always seem to strain myself in the process. Tried the search function with no luck. Can anyone help? Thanks in advance.
      07-26-2007, 08:17 PM   #2
montreal_bimmer
OEMconcept
montreal_bimmer's Avatar
Italy
174
Drives: BMW
2006 325i  [10.00]
never heard of it.... but if you find it, let us know what it looks like...
      07-27-2007, 10:24 AM   #3
dmichael
25
Drives: 2011 GTI
I had this with a M-B c230k. It's called a guide pin. Threaded on one end so you screw it into the uppermost lug hole, since its about 4 inches long, you then slide the wheel hole onto this pin and all the other holes line up. I used it all the time, made changing wheels so much easier. Not sure if the M-B version, which I still have will have the same thread size as BMW, doubt it.
LeatherZ sells this pin for BMW/MINI. http://leatherz.com/Merchant2/mercha...gory_Code=Mini
2008 E90 328i - Sparkling Graphite/Terra/Dark Burl, 6MT, Sport, Premuim, Fold-down seats, iPod/USB(6FL). M-Sport Steering Wheel, ZHP M-Sport Shift knob, Euro fog lights. Euro Split Armrest
      07-27-2007, 04:08 PM   #4
jc777
jc777's Avatar
Drives: E90 325i 2006
http://www.bmw325i.net/wheel_pin.shtml
      07-28-2007, 08:47 AM   #5
Wissam
20
Drives: 2007 e90 328I
Just go to your local hardware store and purchase an M12 bolt, 1.5mm thread pitch (not 1.8), and chop the head off...cheap and simple...
      07-29-2007, 06:11 AM   #6
ENINTY
173
Drives: 2006 325i Sport
The tool you are talking about used to come in every BMW tool kit until the run flats came into use. All it is is a 10" round steel bar, plated (so it won't rust), with a grey plastic end piece that slides into the bolt hole on the hub. I helps line up the wheel bolt holes to the threaded hole in the hub. Any good dealer should get it for you, it's under $10. Or go to a junk yard.
      09-19-2007, 08:26 PM   #7
TurboFan
Ski bum
TurboFan's Avatar
317
Drives: sideways
Call Andy at LeatherZ. I'd never seen one before, he gave me one this evening. Works like a charm.
1999 e46 328i Ti Silver / Black[retired]
2007 e90 335xi Jet Black / Black[retired]
2011 e70 X5 35d Vermillion Red / Cinnamon
2011 e92 M3 LeMans / Fox Red extended
