Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > e90 LCI with 189s on oem sport suspension and 15mm spacers
      09-17-2012, 12:00 AM   #1
GermanMuscle
Once you drive a Bimmer, you always drive a Bimmer
19
Drives: 2011 e90
Anyone have pictures of this setup would be awesome.
      11-18-2012, 02:17 PM   #2
starbai
PPRSWCE
starbai's Avatar
Guyana
654
Drives: 18 Tanzanite Blue F80 ZCP
Still searching hard for 10mm up front and 15 in rear with stock 189's on an otherwise stock LCI e90.
      11-18-2012, 04:44 PM   #3
GermanMuscle
19
Drives: 2011 e90
nope, i decided to go aggressive on wheels and the 189 is not gonna cut it.
      11-18-2012, 07:57 PM   #4
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
63
Drives: Audi SQ5
I have ran 12's on the front and there is still room to go. Depending on year, you can probably go more on the rear too.
      11-19-2012, 10:58 AM   #5
starbai
PPRSWCE
starbai's Avatar
Guyana
654
Thanks for the info but yes I believe you're correct about it being dependent on year.
Do you have any pics of when you did 12mm up front? Was it a pre or post LCI e90??
I'm assuming it's post if it is the same car in your sig. What style wheels were you running at that time too? If post LCI style 189s then id like to try 12mm up front an 15mm in the rear.
      11-20-2012, 05:40 PM   #6
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
63
Drives: Audi SQ5
Pre or post LCI for fronts are the same, IIRC. The rear tracks are different by 8mm.
      11-20-2012, 06:20 PM   #7
starbai
PPRSWCE
starbai's Avatar
Guyana
654
wider or skinnier? that is if wider, 12mm on the lci would produce the same result as 20mm on the pre-lci... correct?
