Will 18x8.5 ET20 square setup fit 335i?
09-16-2012, 06:40 PM | #1 |
BMW Nut
50
Rep 452
Thinking about moving to a 335i or 135i after selling my M3, but i have a square set of VMR VB3 18x8.5 ET20 wheels with Dunlop winters on them that I'd like to keep. Will they fit the 335i (both sedan and coupe)? What about the 135i? I realize it's not the correct forum for that, but hoping someone knows anyway.
I'm pretty sure they will, but I wanted to verify before holding onto them since the M3 buyer wants them. Thanks
12 X5 xDrive35i | Platinum Gray | Oyster | Burl Walnut | Premium | Convenience | 3rd Row | Apps
13 Audi S4 | Misano Red | Black 04 S2000 | Berlina Black | Black |
09-16-2012, 07:30 PM | #2 |
A family of bimmers
2747
Rep 7,742
the 335 should fit. I have et 30 on an 8.5 right now up front and could potentially go to a 20 if i was lower and had a slightly more stretched tire up front. The rear will be fine.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
09-16-2012, 07:42 PM | #3 |
Rep 208
18x8.5 et20, squared should fit on any non-M e90/e92. The stock wheels are 18x8 et34(front) and 18x8.5 et37(rear) for 335s. I'm currently running 18x8.5et20, 18x9.5et22 on my e90 328i(stock zsp suspension) w/ no problems what so ever. Only thing to keep in my though is that you'll need to have just a bit of a stretch up front in order prevent rubbing.
09-16-2012, 09:00 PM | #4 |
232
Rep 2,643
I think it could work on the 335i with winter tires since they are skinny.
With the 1 series 135i I wouldn't even try. Normally offsets need to be around ET40 for 225 tires and there isn't 20mm space to spare. |
09-17-2012, 08:33 AM | #5 |
Moderator
369
Rep 4,745
Has a better chance of fitting a 3 series than a 1 series. This size and offset is not exactly ideal for a winter setup. You would generally want a more narrow wheel and a more tucked in fitment to keep more salt and sand spray inside the fender well (and off your cars paint).
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
09-17-2012, 10:15 AM | #7 | |
BMW Nut
50
Rep 452
Also, tires are 235/40/18. Make any difference?
09-17-2012, 10:32 AM | #8 |
Your'e gonna learrrrrrnn tooooday
38
Rep 595
Lower the offset = Wheel sits more towards the fender
Higher the offset = Wheel sits more towards the suspension components.
2013 BMW 328i MSport F30 - Estoril Blue
"Minds are like parachutes. They only function when they are open." James Dewar |
09-17-2012, 04:19 PM | #9 |
Moderator
369
Rep 4,745
+1
09-17-2012, 09:54 PM | #10 |
BMW Nut
50
Rep 452
Thanks again for the responses. I think I read before that most people were assuming I was using 225 tires, but they're actually 235s. Would this extra width push me over the edge from "go" to "no go"?
