F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Upgrading subs in F30 HK system
proTUNING Freaks
      09-14-2012, 07:06 PM   #1
PrazVT
PrazVT's Avatar
38
Drives: '21 M240i 6mt (soon)
I'm on the verge of getting the combox retrofit done on my f30 and I've been evaluating the HK system in my car over the last 3 weeks I've had it.
While I hate using EQs, after taking an RTA to the HK system, it's sounding a lot better than it did at default settings. I also disabled Logic 7, which while doing a good job bringing out ambient details in songs, tends to add a bit too much midrange for my taste.
The dual subs in the HK system are OK - they don't distort or anything. But they can get boomy if you turn them too much.
What I'd like is better quality bass <100Hz. I think RPM90's suggestion of swapping the woofers sounds promising. While my bass head days are behind me, I got used to the thump of a sealed 12" Rockford sub in my Mazda3's system.
I know a dedicated amp would be ideal, but I suspect the HK amp is enough. Couple of general questions though...
1 - Anyone know the impedance for the HK woofers? Are they 4 ohms?
2 - Would the HK sub enclosures be classified as vented or sealed?
Otherwise ... I see some Rockford Punch Stage 3 8" shallow mount subs that look pretty nice.
Anyway - if you guys have any feedback, would be great.
Thanks,
Praz
      09-15-2012, 10:08 AM   #2
Haarschmerzen
Drives: 320i xdrive
Praz
Sorry I cant help you, but can you share your EQ settings? I listen to electronic music and I want less sub 80hz. It's just too boomy... My temp solution is: pull the bass slider almost all the way down and increase the EQ 100 hz slider up. I am not sure if it really helps but I think it got a litte bit better...
Its a shame that the EQ doesn't support sub 100 hrz!
      09-15-2012, 11:46 AM   #3
PrazVT
PrazVT's Avatar
38
Well that's the thing right - it looks like the sub is crossed over @ 100Hz, so aside from lowering the gain, not a lot you can w/ the subs. Sure I'll take a look at my EQ settings and post back - though keep in mind that it's kinda subjective if you like it or not
f30post
