F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding Helping Non Xenon To Xenon
GetBMWParts
      09-12-2012, 02:24 PM   #1
jrpaz
Drives: 2015 435G MSport
2013 BMW 328i  [0.00]
Good Afternoon,
I want to go from non xenon to xenon in my 2013 328i getting the parts is not hard but I would imagine I would need to code the xenon to have it work properly correct ? Any help or advise will go a long way.
      10-12-2012, 08:16 PM   #2
Sock_Puppet
Sock_Puppet's Avatar
Drives: 2013 328i
*bump
      10-30-2012, 09:05 PM   #3
stossie
Drives: 2012 F30 328i
bump
      10-31-2012, 04:23 AM   #4
demge01
demge01's Avatar
Drives: F30 320ed
There are various settings in the FEM module that relate to Xenon headlight settings, such as the drivers for the vertical and horizontal levelling and much more.
I would compare your file to one set up for Xenons first then explore getting the parts.
Note there are non adaptive xenons and standard xenons which are different parts.
      12-04-2012, 06:18 PM   #5
f302012sold
f302012sold's Avatar
Drives: F30
how do you manage to get the oem xenon headlight parts? for me i surely think this is hardest part - at least for now
      12-05-2012, 08:07 PM   #6
wayman519
79
Drives: E82 N52 6MT A51
2018 BMW X2  [0.00]
2009 128i  [0.00]
ooo, exactly what was on my mind! I was planning on renting an F30 for the day to map the parts and connections needed for Non-coded Xenons (piggyback of the halogen wiring and just sort out the power required for xenons). But like demge01 said, I may also clone/look at the loaners code if its easier.
      12-10-2012, 09:23 AM   #7
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
if you have any success, please let us know
      12-11-2012, 09:46 AM   #8
jrpaz
bump***
      12-18-2012, 09:58 PM   #9
Spk495
No_Country
Drives: 328xi
Can anyone post a list of parts needed to retrofit the bi-xenons on an f30?
      12-18-2012, 10:01 PM   #10
zibawal
36
Drives: 2012 X5D
I am interested too, or at least halo rings
      12-18-2012, 10:08 PM   #11
SamS
866
Drives: Tesla M3 Perf + '18 X3 M40i
Go to realoem.com
      12-19-2012, 05:07 PM   #12
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
http://realoem.com/bmw/showparts.do?...56&hg=63&fg=05
      12-20-2012, 04:15 AM   #13
Dudeonthego
Drives: 2012 BMW 328i - Luxury Line
what is the difference between bi-xenon and xenon ? and how can you tell you have xenon lights ?
My dealer did not go over any of these details....
      01-02-2013, 07:24 AM   #14
luvbirds22
Drives: F30 with Xenon Headlights
i have all the stuff with me now.I need correct wiring guidance because i think the halogen connector wires dont match up with xenon connector as i am able to light up the xenons but drls(angel eyes) and side indicator bulb dont lit up.I am not sure if it has anything to do with the coding stuff but i personally think only issue is wiring ,coding will come into play for errors when all lights lit up
      01-02-2013, 07:30 AM   #15
luvbirds22
any help as regards to wiring will be appreciated.the xenon connector has 8 pins out of which 4 are known to me.pin number 1 unknown,2 is ground,3 being for xenon,4 ground again,5 unknown,6 being for shutter,7 unknown,8 unknown
      01-02-2013, 07:52 AM   #16
kon
Singapore
21
Drives: F30 310i > G20 310i
I could be simplifying things, but having success in doing vehicle option coding, one should be able to use this method to also code in the new option without necessarily meddle at each line/code, option 522 for xenon
      01-02-2013, 11:25 AM   #17
luvbirds22
Could you please explain in detail i didnt actually get u sorry
      01-02-2013, 11:28 AM   #18
eric@helix
eric@helix's Avatar
208
Drives: 01 M Coupe, 08 135i, '12 328i
What have you done for the leveling sensors?
      01-02-2013, 01:00 PM   #19
luvbirds22
i dont care about the self levelling option and also it is not mandatory in india so least concerned about it.at this point of time the most important thing i need to know is which wire goes where in the xenon connector so if anyone knows it will be greatly appreciated
      04-24-2013, 04:05 AM   #20
luvbirds22
hey guys!
ok someone now help me with the coding.what all settings I need to change in there??all the hardware installed in the car already.
      04-24-2013, 12:38 PM   #21
zibawal
36
Drives: 2012 X5D
self leveling is not mandatory perhaps any where, but extremely useful while driving, especially on winding roads.
I am in the same boat with bad base halogen lights
      04-27-2013, 03:24 PM   #22
wayman519
79
2018 BMW X2  [0.00]
2009 128i  [0.00]
hey guys!
Coding wise, you wont need to do much unless you went with adaptive. Did you manage to connect cables correctly? if not, use a multimeter to measure the pins while flicking the light switches in the car.
Could you post the complete parts list you bought and installed?
f30post
