F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Does the car has EDC?? Help Please
Studio RSR
      09-10-2012, 04:55 AM   #1
linhperfume
linhperfume's Avatar
Vietnam
37
Drives: BMW 2011 528i
Hello every body,
before ordering a set of KW V3 for my customer's F30 328i Based. I took a pix and the KW saleperson said it has EDC.
I've just received the KW V3 with EDC delete.
when instaled, I saw the box like in the KW's guide book to install the cancelation kit.
But even without installing the cancelation kit the car has no error codes
So I wonder if the car has EDC??
Thank u alot.
      09-10-2012, 05:13 AM   #2
clarence
53
Drives: F30 328i M-Sport
Run the vin on bmwvin.com , see if the option code is there.
      09-12-2012, 07:23 AM   #3
linhperfume
Vietnam
37
thank u
      09-13-2012, 02:22 AM   #4
UhhItsANT
77
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
Where did you get the carbon fiber stuff?
      09-13-2012, 02:32 AM   #5
sigfe
Drives: F30
Here you are: http://www.shopbmwusa.com/ProductDet...3827&perf=true
      09-17-2012, 01:49 AM   #6
UhhItsANT
77
Originally Posted by sigfe View Post
thanks! is this http://www.shopbmwusa.com/ProductDet...3829&perf=true the shifter you got? because in the picture it shows the cup holder area and stuff, but your picture doesnt have that. With the carbon fiber trip it doesnt mention anything about the shifter.
      09-17-2012, 11:59 PM   #7
sigfe
Drives: F30
Yes, it's the one.
      09-18-2012, 10:03 PM   #8
UhhItsANT
77
Yes, it's the one.
how easy is the install on it? can it be easily done at home with regular screw driver? How long does it take? my 335 is in order right now so i dont have a car to look at but im planning on getting that.
      09-18-2012, 10:23 PM   #9
sigfe
Drives: F30
Well, there are 2 part of this stuff: the carbon fiber part cover the "P" button and the front shift; and the black surface with "M" logo. Use a screw driver to take out the original surface that stick to the shifter by an adhesive. There's a small screw behind it, take out the screw and then you can take out the original front cover.
Replace the carbon fiber cover, screw, and finally put the "M" surface in it. Finish!
      09-19-2012, 12:39 AM   #10
UhhItsANT
77
so basically the screw is under the black plastic that labels R,N,D,D/S etc.? I can remove that by using a flat head screw driver or something thin and flat enough to pop it open as if it check dome, maplights on japanese cars?
      09-19-2012, 01:19 AM   #11
sigfe
Drives: F30
Yup
Search this Thread:
Advanced Search
f30post
