Premature Tire Wear
07-23-2007, 12:33 PM | #1 |
Rep 140
Premature Tire Wear
I have an 06 E90 330 with zsp. I have noticed that within the last few months (after i had my steering rack replaced) my car has had difficulty going straight. If there are any bumps on the road, my car will pull left and right really hard on the freeway. The other day i parked my car and had the wheels turned and i noticed that the inside of my right front wheel was really worn. My rear tires are still fine though and have a few thousand more miles left on them. I have never had front tires wear out quicker than the rears on any of my rear wheel drive cars. Having the insides worn and the instability of the vehicle make me think that there may be too much negative camber on the front wheels.
I have an appointment on thursday to bring it in for this problem, but i have a feeling they will say that this is normal wear and will try to sell me new tires. |
07-23-2007, 02:30 PM | #3 |
Accountant with 335i
15
Rep 199
story on the those stock tires is
that they prematurely wear if you dont put air in your tires every month the front tires loose air moore causing the the tires to go bald really quick hence causing the pull to the side, I promise you once you get your new tires, a lot quiter, and no more pull happened to my gf's car, bmw tried to make her by new tires, had a few kind words about how bad these tires are! ended up only paying for 1 tire ($227)
2007 Titanium Silver w/Black Dakota - Brushed Alumin trim Sport, Premium 6speed
07-23-2007, 04:23 PM | #4 |
Rep 140
I haven't put any air in the tires. Isn't that why there is a built in tire pressure monitor? I figured that would detect any loss of pressure. I guess i'll manually check the pressure before seeing the dealer.
07-24-2007, 09:46 AM | #5 | |
15
Rep 199
but he says that when the air is significantly less (blow out/really low) it will go off so when the air is only 3-5psi lower it wont show it! i discussed with him on how this should have been told to my gf at the time of purchase and that the TPM should have said something, and asked if his manager/bmw could do something and so they did! hope this helps
07-24-2007, 09:55 AM | #6 | |
Rep 140
