Thoughts on wheel/tire setup for track...
07-20-2007, 08:33 AM | #1 |
19
Rep 313
So I'm looking into setting my 335 up for track use next summer. I don't want to run the RFT tires, so I thought I might purchase a set of rims/tires for track use only. For those of you who are track-saavy, what do you think of the following setup:
18x8" Sport Edition KM11 Wheels: http://www.tirerack.com/wheels/Wheel...atin+Sil+Paint Yokohama Parada Spec-2 Tires: http://www.tirerack.com/tires/tires....=Parada+Spec-2 My question is, how will running 18x8 wheels all around impact traction? The standard setup is 18x8.5 in the front, and 18x9.5 in the back. The tire size would be the same as on the current 18x8.5 fronts, but would also be on the back as well. Would I need spacers in the rear? Any thoughts would be appreciated! Thanks! Todd
335i Coupe: Crimson Red / Black
X3 3.0si: Alpine White / Sand Beige |
07-20-2007, 09:25 AM | #2 | |
434
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
I am considering 235/40/18 and 245/35/18 R compounds.
Car is now gone .... :-( |
07-20-2007, 10:55 AM | #3 |
STEVIL Empire
218
Rep 6,297
You should ask this in the Wheel/Tire section.
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
07-20-2007, 10:55 AM | #4 |
Razor sharp handling
23
Rep 619
My advice for the track is to go for 17" and as lightweight as possible. You're going to go through a lot of tires, doing this will save you money and weight. You can get Kosei K1s in 17x8.5 for all four corners, push out the back wheels on spacers (if you need more rear track), and then a set of Yokohama A048s or AD07s (if you need to drive to and from the track in wet). I've seen a couple 335i coupes on the track with this setup and it seemed to work fine. I track my Elise and not my 335i, but I am entertaining the idea of using both cars (the Elise for near tracks and the 335i for far, since I don't have anywhere to keep a trailer, and driving the Elise for more than 4 hours is a beeyotch). If I do track the 335i, that's the route I'm going to take.
1997 E36 328is Arctic Silver: 1997-2003 100k Mi. SOLD
2000 Audi TT Quattro Coupe Lake Silver: 2003-present 35k Mi. SOLD 2006 Lotus Elise Polar Blue/Red 2007 E92 335i Spacegrau/Coral/Al | ZSP/ZPP/ZCW/CA/PDC/NAV Broken in |
07-20-2007, 12:37 PM | #5 | |
19
Rep 313
07-20-2007, 12:42 PM | #6 | |
19
Rep 313
Since you guys seem to know a lot about track setup, do you have any recommendations for suspension setup? I see tirerack (or bav auto I don't remember which now) has a Koni damper/Eibach Pro spring set for around $850. Is this worth it? Will it be better than stock? Is it worth the money for a full Bilstein coil-over setup?
07-20-2007, 01:00 PM | #7 | |
23
Rep 619
You can get 17" options from tirerack by selecting your car as the base model rather than sports package. The other advice I can give you is to wait on suspension mods until you've had a bit of experience. The stock sports package is a little soft for undulating roads (i.e. floaty) but very well balanced and predictable -- good for learning. If/when you get better, you'll want a stiffer suspension, but it's not really necessary until you've surpassed the limits of the stock setup. Having a really advanced race/sport type suspension as a novice can actually be bad, because it may do things you're not expecting, like oversteer more quickly. My best advice is to sign up for a BMWCCA driver's education track day and bring your 335i with whatever set of lightweight wheels and grippy tires you can afford. Our car will run with the best of them just like that.
07-20-2007, 01:10 PM | #8 | |
19
Rep 313
Anyways, thanks again for the help. I'm doing watkins glen in the C4S in 2 weeks with PCA. I can't wait to get my car out there next year!
07-20-2007, 02:21 PM | #9 |
23
Rep 619
That's great! I did a Watkins Glen BMWCCA DE in June and LOVED it. I ran the Elise, but that track is great for the 335i because it is really fast with long straights. There were a couple 335i coupes at that event and they were really fast.
I'm having the same dilemma with the harness question, I have been pretty much been scared away from 4 point harnesses by everyone who says they're dangerous, and in order to get a 5 point setup, I'm going to need new seats. Anyway, have fun!
07-20-2007, 04:59 PM | #10 |
434
Rep 4,380
I personally would not suggest getting a scroth rallye 3 or 4 set up in a street car. Five or six point restraints prevent submarining..where you slide under the belts and collide with the dash. I had 5pt restrainst on my spec miata race car...but I also had a full roll cage. I still dont think getting restraints without a roll bar or roll cage is safe..if you turn over...and the roof smashes down..you have no where to swirm to. When you need 5-6pt restraints in your street car is the time when you need to by a dedicated track car.
