2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums ASIA Is this gonna fit?
      08-20-2012, 09:32 AM   #1
NCEC
Drives: F10
Is this gonna fit?
front 20x8.5 et 15
rear 20x9.5 et 20
Got no answer from the wheels forum, hope to get it answer here, thanks in advance!
      08-20-2012, 10:17 AM   #2
bobblehead
bobblehead's Avatar
256
Drives: warp speed
No. front may be okay but the back will probably rub your fender when going over bumpy roads. Those are more for the M3 fitment
your front wheel will be pushed out by 18mm.
your rear wheel will be pushed out by 26mm.
      08-20-2012, 10:54 AM   #3
NCEC
Drives: F10
Thanks, wow it will stick out that much.....So whats the maximum offset that would work for our F10?
      08-20-2012, 11:17 AM   #4
bobblehead
bobblehead's Avatar
256
Drives: warp speed
As far as I have seen. the limit is around +18-20mm ... anything beyond that will either look very ugly and rub against the fender.
For the front: 20 * 9 et 23 will give you +16mm sticking out
For the rear: 20 *9 et 28 will give you +16mm sticking out
      08-20-2012, 11:21 AM   #5
bobblehead
bobblehead's Avatar
256
Drives: warp speed
If you want a direct fit (translated over from stock 19 to 20), then
Front: 20x8.5 ET33 - 245/35/20
Rear: 20x9 ET44 - 275/30/20
      08-21-2012, 10:27 AM   #6
NCEC
Drives: F10
thank you much...I was about to order a set of wheel that size! Glad to find out first
      08-21-2012, 10:53 AM   #7
bobblehead
bobblehead's Avatar
256
Drives: warp speed
May I ask what you are ordering ?
If BMW stock 311 or 356 ? The 20's is going to weight around 30lbs each. That's really heavy.
      08-22-2012, 11:12 AM   #8
NCEC
Drives: F10
I'm looking into a set of 20" Alpina classic, they have that on their tech sheet but I guess those are the offset for E60, they didn't specify what offset for F10
      08-22-2012, 11:25 AM   #9
NCEC
Drives: F10
Just wonder what if I have 20x8.5ET15 for both front and rear? Would that work?
      08-22-2012, 12:06 PM   #10
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Alpina Classics - 20" - for E60 5series
Front alloy wheels: 20x8.5" ET20
Rear alloy wheels: 20x9.5" ET24
      08-22-2012, 12:15 PM   #11
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Actually, what do you have right now on your F10 F & R ? Before I can recalc. the setup using the Alpina Classics.
      08-25-2012, 02:55 AM   #12
NCEC
Drives: F10
I'm having the OEM 17" tire size is 225/55/17 not sure about offset but should be 30
5post
