Back Number Plate 318 LCI
08-08-2012, 05:01 PM | #1 |
New Owner, First BMW
Rep 53
Hi
I have removed my back number plate so I could put my shortened personal plate on. The original was held on with 2 screws but I've fixed my private plate on with double sided tape. Problem is when it's warm the glue melts and the number plate falls off so I'm going to hold it on with screws. Problem is I've binned the original plate so cannot use that to mark the private plate on where I should drill the fixing holes. Anyone got a template or an old plate or an idea how I can solve my problem ?
318d Exclusive 2011, Cruise Control, Media Pack Professional, 17" Style 285 Alloy Wheels, Sapphire Black, Oyster/Black Dakota Leather
08-08-2012, 05:11 PM | #3 |
Rep 53
Yeah I could but that's my last resort if I'm honest.
Chances are the plate would be slightly off centre, squint or the wrong height. An old plate from another car or a template would be ideal.
08-09-2012, 02:39 AM | #5 | |
26
Rep 639
I used the whole roll to do both plates. (all the way around) http://www.ebay.co.uk/itm/New-5m-x-1...item3a5444799b HTH |
08-09-2012, 04:46 AM | #6 |
1042
Rep 6,946
4 proper double sided number plate pads is all you need, they will stick for ever IF you have both surfaces clean. Give the mounting area on the car a clean with something like Autoglym Tar Remover to remove all the dirt and grime built up behind the old plate.
When I put plates on that way its usually a big job to pull them off when changing so can't see any adhesion issues. |
08-09-2012, 04:53 AM | #7 |
Dieseasal
204
Rep 6,881
This one's easy.
run a soapy cloth over the back of the car so it's slick, and then: stick a big blob of blue tac on each hole (loosely) and then press the plate onto it. Remove it again. You'll have bluetack on the plate exactly where the holes need to be. (NB. Don't push it in too much and make suor else you have a new problem, picking blu tack from screw holes on the boot lid ) Could you not otherwise simply measure the gap between holes with a tape measure and apply the same to the back of the plate also..
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport |
08-09-2012, 05:34 AM | #8 |
39
Rep 838
Drives: LCI M135i
What are you going to do with the holes left in your front bumper?
I am in the same situation, I have a smaller private plate. The rear is fine as the holes are central but the smaller plate doesn't cover the holes in the front bumper as they are right at the ends. Why BMW drilled holes in the bumper is beyond me!!! |
08-09-2012, 07:31 AM | #9 | |
1042
Rep 6,946
08-09-2012, 07:33 AM | #10 | |
28
Rep 405
08-09-2012, 12:51 PM | #13 |
Rep 53
Anyone got an old plate they could send me? I'd pay postage.
08-09-2012, 05:08 PM | #14 |
Rep 116
Can't you pop down the local dealer and ask for a old plate or template?
or even ask your dealer for some double sided tape? I've done that with my dealer and you need some serious effort to rip the plates off with there tape! |
08-10-2012, 04:18 AM | #15 | |
Rep 53
08-13-2012, 03:54 PM | #17 |
Rep 53
Dealer sorted it
