Strange coolant temperature behaviour
08-07-2012, 09:36 AM | #1 |
99
Rep 403
Running at a constant 70mph in 6th (manual mode), and my temperature is sitting at about 92 degrees.
Without changing speed, if I drop down to 4th gear the temperature drops to about 84 degrees within about a 1/4 mile. And the reverse if I change back up to 6th. Both thermostats have been changed fairly recently. This seems counter-intuitive, can anyone suggest an explanation? |
08-07-2012, 09:40 AM | #2 |
1397
Rep 8,083
Engine spinning faster therefore the water-pump is turning faster
I suspect the cooling system is designed to lower the temperature towards the bottom-end of the acceptable window if the engine us run at higher speeds.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
08-07-2012, 09:40 AM | #3 | |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
I have heard BMW didn't fit an actual gauge because of the 335d fluctuating temp range, they didn't want to frighten owners. Dont worry about it mate
997.2 GT3
08-07-2012, 09:52 AM | #4 |
99
Rep 403
That might explain it, I just thought 'more revs = more heat' It might be worth remembering if the car is ever running too hot.
Not worried at all, just curious! |
08-07-2012, 10:08 AM | #5 |
886
Rep 9,097
Do you have electric pump same as 335i?
or do you have traditional pump? You have answer to your question already but I'd like to know if 335d and 335i both shares electric water pump?
08-07-2012, 10:18 AM | #6 |
99
Rep 403
It's a mechanical (belt driven) pump I believe. I didn't realise the 335i was different.
08-07-2012, 12:05 PM | #7 | |
290
Rep 2,598
