F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY Headrest Fix
Studio RSR
      08-05-2012, 12:58 PM   #1
Jadar
Dejan
Jadar's Avatar
Serbia
1751
Drives: 2018 Audi S3
I was very annoyed by the fact that the headrest was not able to go all the way down or you couldnt take it all the way out. Here is the simple fix.
Tools: 7mm socket and ratchet. And a pick tool.
You may have to move the seat back and forth to give you more room.
1. At the Rear base of your front seat locate the 2 push pins. This is basically the only thing holding the back plastic part on. Gently pull down with both hands and the pins will come free. Slide the Plastic panel straight down. This gives you access to the headrest clamp.
2. Look for the 7mm clamp usually on the left headrest stem. Undo it and slide the clamp off. This will allow you to remove the headrest completely out of the seat.
3. Locate the black plastic cap with out the adjustor. Its on the Right hand side. Gently pry up on the cap. Take your time be careful. This will expose the 2 springs that need to be removed.
4. Using a pick tool romove the 2 springs. Dont throwh them away you may want to reverse this process one day. This allows the plastic clip inside to move freely. Its whats preventing the head rest from moving all the way down. Reinstall the cap. And then the headrest. Then the plastic backing cover.
I also left out the clamp so I can take out the headrest if I want.
YOURE DONE! Very simple.
      08-05-2012, 01:25 PM   #2
328i4me
Drives: 08 E92 335xi
nice write up! ill be doing this, once i receive my car next week!
      08-05-2012, 02:31 PM   #3
Jadar
Dejan
Jadar's Avatar
Serbia
1751
Literally took me 15-20 minutes. And I stopped to take pics.
FBO-PS1 and stuff
      08-06-2012, 04:00 PM   #4
gerbs
woof
gerbs's Avatar
82
Drives: M6
Cool thanks!
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      08-06-2012, 04:34 PM   #5
DrivenByE30
DrivenByE30's Avatar
France
578
Drives: '12 F30 Lux 335i 6MT
very nice !! Thanks for Sharing !
      08-20-2012, 06:04 AM   #6
steadymoddn504
14
Drives: e36 m3
12 BMW 328i  [0.00]
Re: Diy Headrest Fix
hello all. we can all agree this headrest issue just seemed a little off..(must be the ocd) but its in place for a reason: TO MOD! jk so i also tried this mod but noticed that i didn't have the clamps on mine instead it was a 20 torx screw on one of the bars. anyway so after doing one side per dd1981 just going through the steps, it dawned to me years later that i didn't even need to do steps 1-2. the only thing i needed to do was pry up on the cap that you cant squeeze down-on while the head rest is still on there (bc the cap covers the internal adjuster thingy), bring down the head rest and then pressed down on both of them simultaneously once you are on the last knotch to bring it down all the way. too late to bare with me but you'll have about 1-2 inches of space to snap the cap back on and your done.
ps still be gentle when prying the cap and make sure u snap it back on real good. it has 3 groves that need to be snapped down
still or cant figure it out then just go through with all the steps noted before. it just depends what you want and how much time you have.. ie i only wanted the headrest to be flush down so i went through all the steps on the passenger side and cut the steps in half for the driver side whatever works for you. if you pull up on it then it'll snap back in place and you will have to do it again
the only thing in this world that gives orders is balls. You got that? Balls.
natesi204.00
      08-20-2012, 08:02 PM   #7
Jadar
Dejan
Jadar's Avatar
Serbia
1751
Yep indeed you can skip the 1st two steps, I covered that in another post. The reason I did the whole thing is I want to be able to remove my headrests so I wanted the clamp off on the stem.
Good job and thanks for adding. Headrests Lookin much better.
FBO-PS1 and stuff
      08-21-2012, 03:31 AM   #8
JamesMA
JamesMA's Avatar
80
Drives: 2018 F80 ZCP
I have to do this one. Maybe this weekend. Good stuff and thank you.
2023 G80 ///M3x Comp. BSM on Black M Brakes
Gone: 2018 F80 ///M3 ZCP 6 MT, 2013 F30 335i 6MT M-Sport
      08-23-2012, 05:17 AM   #9
steadymoddn504
14
Drives: e36 m3
12 BMW 328i  [0.00]
good stuff! thanks for sharing in the first place, it definetly helped
      09-13-2012, 08:59 PM   #10
RonSwanson
**Fortune Favors The Brave**
RonSwanson's Avatar
13
Drives: 2013 328i M Sport
Just did this "the easy way" and it was pretty darn easy. Took 3 minutes. Thanks good idea!
2013 ///M Sport Estoril Blue - Navigation - Enhanced BT - Xenons - Sport Auto
      09-14-2012, 09:43 AM   #11
diesel86
16
Drives: 2012 BMW 328i Sportline
Maybe it's because I'm on the taller side so have never had my headrests all the way down on any vehicle I have ever owned...but what it the point of this mod? Cosmetic only or is there a functional purpose.
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy.
      09-17-2012, 01:27 PM   #12
loz3rxfreak
19
Drives: 2012 328i
Thank you for this fix. Was very simple to do. Took me 5 mins
      09-17-2012, 01:44 PM   #13
RonSwanson
RonSwanson's Avatar
13
Only drawback is you can't tilt the headrest forward when its all the way down..which also looks good and might be a bit more functional. But I notice some F30s don't have that button to tilt forward on the side of the headrest. Not sure if that's a 2013 thing or something in the trim ordered.
      09-17-2012, 08:58 PM   #14
Jadar
Dejan
Jadar's Avatar
Serbia
1751
Yeah thats kind of the only bad thing, but I never tilt mine. I have that button on the side, not sure wich models have it and wich dont. Its not something I would opt for, I never use it.
FBO-PS1 and stuff
      10-10-2012, 09:15 PM   #15
ocso1606
ocso1606's Avatar
42
Drives: 2013 335i M
2007 BMW 525xi  [0.00]
2010 Volvo  [0.00]
2013 BMW 335i M-Sport  [0.00]
Thats a good idea. Thanks
M5 with lots of goodies
      12-27-2012, 10:17 AM   #16
ThreeTwentyEightI
ThreeTwentyEightI's Avatar
38
Drives: No BMW right now :(
Interesting... but I think you might be removing a safety feature by doing this. In the stock set up the head rest has a movement (front to back) that seems to be for neck injury prevention. I might be wrong but just a thought.
Retired: 99' E46 323i AW / 06' E90 330i SG / 09' LCI E90 335i MB / 13' F30 335i EBII
15' F30 / 328i / Msport /// xDrive / Mineral Grey / Oyster / Anthracite
Driving: No BMW right now
      12-27-2012, 06:05 PM   #17
Jadar
Dejan
Jadar's Avatar
Serbia
1751
It could very well be for safety, it still does tilt just not as much.
FBO-PS1 and stuff
      12-29-2012, 04:25 PM   #18
themoveforward
themoveforward's Avatar
12
Drives: 13' 328xi MG mSport
This was done to comply with Federal safety standards. In fact, there was a recall on early production F30 models due to this fact.
      04-06-2013, 06:14 AM   #19
dude987
Germany
41
Drives: BMW 335i xDrive M-Sport DHP
Just completed my set up. Appreciate the DIY. I may opt to buy the switched cover and replace with the fixed cover.
      04-22-2013, 03:23 PM   #20
gteye
Drives: F30
Great help. Thanks
      04-25-2013, 09:27 AM   #21
IM2C
IM2C's Avatar
2065
Drives: ∞ Improbability Drive
Thanks
Great DIY.
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
      05-04-2013, 12:35 PM   #22
kromix
kromix's Avatar
262
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
I dont' get how you guys got the spring out? I was trying now, I almost bent/broke the plastic piece at the end the spring is on, there almost no room for manuevering the spring out???? Help! lol
Search this Thread:
Advanced Search
f30post
