Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Those Of You Who Recoded To AGM Batteries...
      08-01-2012, 03:48 PM   #1
Former_Boosted_IS
307
Drives: 4 Wheels
Were you able to verify using INPA that the charging strategy has changed? I changed my CAS file to ...
KLASSE_BATTERIE
40ah_agm
After coding the DME, I registered the battery using Tool32. However, when I check the charging strategy in INPA it still shows 81 aH. Has anyone been able to confirm they changed the charging strategy to AGM 40 ah using coding plus tool32?
654 RWHP ... ! Vishnu/FFTEC Single Turbo 335
      08-01-2012, 04:08 PM   #2
Elliott@DetailAddict
300
Drives: E90
Did you update your VO?
      08-01-2012, 04:13 PM   #3
Former_Boosted_IS
307
Drives: 4 Wheels
Grant, I did not. I only coded the CAS module then reset the battery adaption using tool32. I have never read anywhere that I need to update my VO? How would I approach that and what do I need to do?
      08-01-2012, 04:57 PM   #4
300
Drives: E90
E B046 BATT_46AH //46 Ah-Batterie
E B055 BATT_55AH //55 Ah-Batterie
E B070 BATT_70AH //70 Ah-Batterie
E B080 BATT_80AH //80 Ah-Batterie
E B090 BATT_90AH //90 Ah-Batterie
E A070 BATT_AGM_70AH //70 Ah-AGM Batterie
E A080 BATT_AGM_80AH //80 Ah-AGM Batterie
E A090 BATT_AGM_90AH //90 Ah-AGM Batterie
In your VO (FA) List you should find $B080 if your old battery is 81 ah.
You will need to delete that, add the closest match from the list above back in, then FA_Write the new VO to CAS and FRM/NFRM, THEN code CAS. Then you can use the register battery option in Tool32.
      08-01-2012, 04:58 PM   #5
Former_Boosted_IS
307
Drives: 4 Wheels
The DIY shows there is a 40 ah option for the AGM batteries, but it doesn't show that in the this list???
      08-01-2012, 05:00 PM   #6
300
Drives: E90
Hm. Try adding $A040 and see if it gives you an error (meaning that the VO code is invalid).
      08-01-2012, 05:01 PM   #7
Former_Boosted_IS
307
Drives: 4 Wheels
Do I FA_Write only the NFRM and CAS? When I am done, do I just exit?
      08-01-2012, 05:08 PM   #8
300
Drives: E90
Follow the steps for updating VO. There is a DIY on here.
In a nutshell...
Use Expert Mode
Go to Enter FA, delete the old code add the new one
Then Process ECU, CAS, Job: FA_Write.
Repeat for NFRM
Then go back to CAS and SG_Codrien still in expert mode.
Good luck!
      08-02-2012, 05:59 AM   #9
Surly73
535
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
I just recently went through all of the steps for this in the battery replacement thread. I went with 90Ah AGM but the steps are the same. My charging strategy went from 90.0 to 91.0.
http://www.e90post.com/forums/showpo...5&postcount=29
      08-02-2012, 12:46 PM   #10
300
Drives: E90
Yup. Good write up. Thats what I stated above.
Instead of manually changing the line in CAS, after you update the VO in both modules and process the cas, it is changed automatically.
      08-02-2012, 01:00 PM   #11
Former_Boosted_IS
307
Drives: 4 Wheels
Grant, can I change the line in the CAS manually so I don't lose the coding I have done using the Expertmode?
      08-02-2012, 01:16 PM   #12
300
Drives: E90
You can. I'm just not sure that is the only line that changes when you reset it to the new VO.
Surly said his worked fine doing that so you can try
      08-02-2012, 01:29 PM   #13
Former_Boosted_IS
307
Drives: 4 Wheels
Ok cool. I will try to confirm if there is a 40ah_agm setting in the VO as well.
      08-02-2012, 05:38 PM   #14
Surly73
535
It didn't on my car, I still had to code the option in CAS as well as the VO/FA. I realize my sample size is 1, but maybe some cars update and others don't. I would still check it manually using NCS expert mode if it were my car.
      08-04-2012, 10:53 PM   #15
Former_Boosted_IS
307
Drives: 4 Wheels
Grant, it does allow you to manually code the CAS line KLASSE_BATTERIE. I can confirm there is no 40ah AGM option, so I coded the 70 AGM. I confirmed in INPA and it is charging correctly.
      03-09-2014, 07:54 PM   #16
bmwstone
Drives: 2008 328i
Hey guys, sorry to raise this from the dead but I have a few questions about this as I am trying to do this also... So everything mentioned above can be done or should be done in expert mode? That is update the VO and code the CAS?
Also Im new to coding... Should the VO and CAS be altered while ignition is on or off?
      04-10-2014, 07:54 PM   #17
bdwyer
bdwyer's Avatar
Drives: '11 335d
So... In my CAS and NFRM I see -B090, not $B090. Should I be deleting -B090 and replacing with -A090 or $A090?
'11 335d Sport
CCNP, MCITP-EA
