Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Code reading
      07-29-2012, 02:48 AM   #1
Yerfdog
Drives: M4 Comp 2020
Code reading
Guys,
Anyone know a quick way to read the ECU codes on a 330d.
I have used the likes of VAG Com when I have Audis. I think I got a bust injector. Lumpy tick over, loud ticking from engine and a bit slow to 2000 rpm.
Any ideas how to find out what's wrong?
      07-31-2012, 02:12 AM   #2
Yerfdog
No one got any ideas?
      07-31-2012, 06:03 AM   #3
WNeill
Drives: BMW 325i SE Coupe
I have always used INPA on my BMWs. I also use DIS/GT1 if you want your diagnostics a little more detailed. Usually INPA is sufficient.
Contact 'jimmy' on www.bmw5.co.uk, tell him I sent you
      07-31-2012, 06:45 AM   #4
mistryn
mistryn's Avatar
147
Drives: BMW 335D
there are a few cables you can buy
BT - Bavarian Technic - which I think you can buy from overseas only (pm neil@juiced tuning)
yu can buy leads off ebay that come with software - INPA/DIS (latter pain to install) whchi will give you the ability to read and clear codes
      07-31-2012, 07:18 AM   #5
daveleach
26
Drives: 335d
I have recently purchased a cable off eBay with the software and can vouch for them being a pain in the arse to install and use.
However I have successfully done it, and have cleared codes after recently changing some parts on my car.
      07-31-2012, 08:36 AM   #6
WNeill
Yes, DIS can be a real pain to install, but ultimately worth it
      08-03-2012, 01:47 AM   #7
Yerfdog
Thanks guys . Does anyone know of DiS can use the same cable as VAG com?
      08-03-2012, 03:42 AM   #8
daveleach
26
Drives: 335d
Can't answer your question.
But I don't mind hooking your car up and reading codes for you.
I'm near j5 of the m4 if it's any good for you.
