Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > removing centre console
      07-28-2012, 10:35 AM   #1
gchild
23
Drives: honda
Hi,
whats the best way to remove the centre console trim that has auto leaver and pro idrive?
seen this 'how to' but its for manual non-idrive
http://www.e90post.com/forums/showthread.php?t=137527
cheers
      07-28-2012, 12:05 PM   #2
Cyprio
Cyprio's Avatar
33
Drives: 2014 Audi S4 B/Edition
You should be okay using that DIY.
I can't see what difference it makes whether it's manual or auto - unless I'm missing something!
The manual gear selector looks like there is more work involved as you have to unclip the Leather gaitor from the centre console, which in turn looks like it just slots over the idrive control knob.
      07-28-2012, 12:50 PM   #3
acerboo
England
179
Drives: e92 335d lci
be careful when you pull your knob off, grip hard and jerk upwards just dont hit yourself in the face with it!
      07-28-2012, 01:08 PM   #4
xs2man
xs2man's Avatar
18
Drives: 2013 F11 530d M-Sport
530d M-Sport Touring.
      07-28-2012, 01:49 PM   #5
gchild
23
Drives: honda
Does anything have to be done for the switch behind the knob?
Also assume there will be some electrical type plugs to remove under the surround/gator?
      07-28-2012, 01:52 PM   #6
lemans 330d
lemans 330d's Avatar
166
Drives: 330d M sport
put the car in drive position as if you leave it in park its awkward to lift console out and its easier to remove shift knob
330d M Sport Tourer / Arctic White / 403M Alloys / Privacy Glass / Logic 7 / Heated Leather Seats / High Beam Assist / Bluetooth / Nbt Nav / Auto Lights & Wipers / Front & Rear Park Control /
      07-29-2012, 12:04 PM   #7
gchild
23
Drives: honda
Having done this now on my e90 pre lci, I can add my 2 pence worth if anyone else needs to do this.
1. As said by other posters, the auto knob just comes straight off without too much force
2. The gator comes up by squeezing from the base
3. The auto plastic surround comes up by gripping it on the inside. Be careful as there are two electrical connectors under it. I could remove blue one, but not the other so left the plastic bit hanging loose. That will slide through the console trim hole
You also need to disconnect the connector for the cigarette lighter. Chunky white plug
4. The console trim comes up by lifting from the points where the sponge parts are. I used a screw driver for some subtle leverage
5. You work the trim round and it will come up, then pull towards the back to free it from under the dash
6. The idrive controller has four screws holding it on the trim. Un screw, and the centre console trim will be free.
Hope this helps.
