Underseat Woofer help
07-22-2012, 10:18 AM | #1 |
Rep 62
I've bought the Alpine retro fit kit but while I'm installing it I'm going to upgrade the under seat woofer to either Hertz of earthquake with an amp. The install is pretty straight forward and my only question is where is the best place to pick up the audio input from the head unit to the amp and what channel do I use, front rear or existing lines into the woofers ?
Cheers Andy
E90 Alpina D3 MT :No 566 Titan Silver
E36 328i sport E34 525i sport E28 528i (86) |
07-22-2012, 10:47 AM | #2 |
244
Rep 2,811
Drives: Jaguar XE P250 HSE
As I understand it, the Alpine unit has two outputs specifically for the subs so just use them for your new subs.
07-22-2012, 11:04 AM | #3 | |
118
Rep 2,216
Drives: E91 330d M Sport
You don't need any extra feeds or any extra amps - everything's taken care of with the looms supplied. All you need to do, if you choose to, is ugrade the subs themselves.
Just how many Yorkshire sheep can you fit inside one exhaust?
07-22-2012, 11:30 AM | #4 |
Rep 62
Thanks guys, I'd be lost without this site..
Just to be clear, all I do is change the Subs and the feeds will sort themselves out within the install of the Alpine kit ? If so it's off to search for the subs.
07-22-2012, 01:10 PM | #5 | |
886
Rep 9,097
Earthquakes (SWS-8) will be underpowered (150w each) with alpine amplifier (80W max). You can get away with it, but 2 disadvantages: a) Additional load on alpine amp on max volume. b) You will never listen to true potential of SWS-8s. I have listened music in following cars: 1- Alpine kit with OEM base subs 2- Alpine kit with hi-fi subs 3- Alpine kit with hi-fi subs and HU coded to Hi-fi 4- Aftermarket Amp with components + SWS-8s Comparing alpine kits, 3rd options sounds best. Hi-fi subs with alpine kit + coded HU brings best combination. However if you like punchy bass, SWS-8s are must upgrade and will hardly sound reasonable with Alpine kit.
07-22-2012, 03:28 PM | #6 |
106
Rep 1,800
When you say Hifi subs, are these BMW subs from an upgraded factory setup?
Also, what does the coding of the head unit do?
Black 330d E90 LCI M Sport Saloon Auto. Privacy Glass, Cream Leather, 6FL, I-Drive/Nav/Bluetooth, Alpine hifi upgrade.
07-22-2012, 04:00 PM | #7 | |
886
Rep 9,097
Tom sold plenty of them in Uk classified and they sound great. Hi-fi coding takes out bmw pathetic equaliser settings and convert output of HU to low level balanced output (input to alpine amplifier). Ultimately you end up with less distortion on high volume.
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play Last edited by makkan00; 07-22-2012 at 05:05 PM.. |
07-22-2012, 04:30 PM | #8 |
Rep 62
Great.. and so to my origianl question then..
Where can pick up the audio line in to the "after market" amp I'll need for the earthquakes ? And if I did go option 3, how do you git the hu re coded ?
07-22-2012, 05:03 PM | #9 | |
886
Rep 9,097
If not, then it really depends on you. You will require signals from front channel, which you can get from the back of HU or from the sub connectors. You can ask your local dealer, if they can help with coding. Or you can try coders in your region from sticky thread 'Coders in UK'. Make sure whoever does the job, should do it properly with bmw softwares, otherwise it is very likely that if your car get modules update, your coding will be wiped. HTH.
07-23-2012, 03:21 AM | #10 | |
Rep 228
E90 330d - N57 Prof Nav - 6FL - Visability Pack - Alpine Hi-Fi Upgrade - L7 Subwoofers - L7 rear mids + tweeters - 6FL |
07-23-2012, 06:48 AM | #11 |
886
Rep 9,097
My bad. I meant to say 4ohm bmw susb, whether they are from L7 or hi-fi, they are great.
07-23-2012, 09:12 AM | #12 |
106
Rep 1,800
How much is a set of L7s? Are these 100% plug and play - Could a Numpty fit them?! (i.e me) Do you need to remove the seats to fit them?
07-23-2012, 10:10 AM | #13 | |
886
Rep 9,097
Read this posting and it will give you idea what you should be looking to upgrade. You will require T50 to open your front seats, and just by tilting you can change your subs + enclosures.
07-23-2012, 10:11 AM | #14 |
886
Rep 9,097
If you already have Alpine kit and have not bought SWS-8s, then it would be wiser to get L7 subs and go with all OEM route with alpine kit.
07-23-2012, 02:13 PM | #15 | |
106
Rep 1,800
Very tempting!
07-23-2012, 02:19 PM | #16 |
258
Rep 3,815
just curious been toying with sws-8s for my L7 kit but reading this bit confused. Previously I recall few posts talking about SWS for L7 kits and it mentions they should be teh 2Ohm version if you have the OEM L7 kit.
But reading this it seems they need to be 4ohm whcih leaves me pretyy much confused whcih is the right solution
F30 335i M Sport - now departed
07-23-2012, 02:45 PM | #17 | |
886
Rep 9,097
In all honesty, it is not going to make much difference, if you will stay with stock amplifier, and your subs are already pretty reasonable. However if you have hi-fi, they come with 2ohm subs, and in that case, you will require 2ohm version of SWS-8s.
07-23-2012, 02:52 PM | #18 |
258
Rep 3,815
Thanks thats the joy of searches you find lots but not always right
what I find with the stock L7 subs is they max out when on high volume and distor the sounds. I almost need to re setup the sound somehow to force less base into the mids in the doors as I fear I might pop another one soon. Plan was to do the subs first and then look at if needed a dedicated amp., Looking around foound these ground zero subs though not sure if they are worth it at all comparing to the l7 http://www.caraudiodirect.co.uk/grou...zmw200neo.html
07-23-2012, 04:21 PM | #19 | |
886
Rep 9,097
Sub which you mentioned in your link can be straight swap as its 100W and can be powered by factory amp, however depth is 59mm. SWS-8s measures approx 52 mm, and it requires spacer of 2-3 mm or modification of OEM subs enclosures. So comparing to SWS8s, these subs will defo require bracket / spacers. Before you make any move, you should see if you have new subs which are permanently fitted in enclosures, as if you do so, then upgrading to these subs seems bit of a dream.
07-24-2012, 01:08 AM | #21 | ||
118
Rep 2,216
07-24-2012, 01:29 AM | #22 | |
Rep 228
