Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Does any one do coding in the westchester area?
      07-09-2012, 06:26 AM   #1
Big Momma 328i
Drives: 328i
I would like to have my seatbelt warning removed though i always wear my seatbelt it gets really annoying and also wanted to know if there is a code to automaticaly open/ close windows and sunroof via key fob. For a 2008 328i.
      07-09-2012, 07:08 AM   #2
Big Momma 328i
Drives: 328i
I actually found a place in queens that does BMW the coding.
      07-09-2012, 08:13 AM   #3
cn555ic
cn555ic's Avatar
441
Drives: 335i
Do a search in the tri state area and it would actually be so easy to find if you looked
      07-09-2012, 12:03 PM   #4
Big Momma 328i
Drives: 328i
I know but couldnt find one in westchester thats why i had to drive all the way to queens.
      07-12-2012, 11:06 PM   #5
toicy4ya
toicy4ya's Avatar
47
Drives: 06 BMW 330XI
How did it go? How were their prices?
2006 330XI BSM, Terra Cotta Leather Interior, ZSP, ZPP, ZWP, ZCV, Comfort Access, Adaptive Xenon, Steptronic, Logic 7, Nav w/ IDrive
      07-13-2012, 12:02 AM   #6
Big Momma 328i
Drives: 328i
It went fairly well he charged me 40 bucks for removing the seatbelt warning, open close windows and sun roof via key fob and also side mirrors fold up and down upon locking and unlocking the car. My main concern was the seatbelt warning i also wanted to try out other features but he was too buzy he told me to go back some time next week for other codings. i didnt spend more then 30 minutes there and $40 is not much but i guess i could of bought the wire and did it myself for around that price.
      07-13-2012, 12:12 AM   #7
Big Momma 328i
Drives: 328i
Feature Activations (popular options are italicized) Airbag Related:
1) Turn off seatbelt chime for driver
2) Turn off seatbelt chime for passenger
3) RACE SEAT CODING (Remove MRS errors, enables MRS/SRS functionality) 4) Coding for those with roll cage, racing cars with removed airbags, etc..
Navigation Related:
1) Enable DVD in Motion (09 – 12 Cars)
2) Disable iDrive “accept” message on startup
3) Turn off iDrive Fasten Belts Warning
4) Add a fuel stop suggestion option
5) Add DSC Off option to MDrive settings
6) Have eight shortcut buttons instead of 6 (makes FM/AM and Mode Buttons user assignable Shortcuts)
7) Internet Access (2011 + Cars)
8) BMW Live Activation (2011 + Cars)
(See this link for pictures http://www.m3post.com/forums/showpost.php?p=11735044&postcount=308 )
Car Access Related:
1) Rolling of windows and sunroof up with the key (holding lock)
2) Folding the mirrors with the key (holding lock)
3) Automatic Unlock when key is removed / car is turned off (no double pull!) 4) Enabling Panic alarm as well as retrofitting the factory alarm system
5) Set the sunroof to automatically close when rain is detected
6) Allow opening/closing from the remote on vehicles with a motorized hatch 7) Set alarm parameters / beeps / notifications / disarm method
8) Allow the windows to move up and down even with door interruption
9) Turn off the headlight washing system when you clean your windshield
10) Allow the wipers to complete their cycle after the car is turned off
      07-13-2012, 12:13 AM   #8
Big Momma 328i
Drives: 328i
Lighting Related:
1) Factory Angel Eye Brightness Coding! Make it whiter and brighter! 2) Euro corner delete:
a. Turn off amber corners when headlights on
b. Turn off headlight corner LED’s when headlights on
c. Turn on/off LED’s when high beams are activated
d. Enable/Disable LED’s and corner lights when parking lights on
3) Welcome light activations
a. Set how the welcome lights come on –
b. Fading or Instant on for Angel eyes, corner lights, fog lights, rear fog
lights, rear tail lights, rear brake lights, under handle lights, parking
lights, and LED’s
4) Turn off inner/outer, or both daytime running lights on rear taillights 5) Make the emergency signals double blink when turned on
6) Make the fog lights cornering lights (for cars equipped with fog lights) 7) Remove light errors for aftermarket lighting, LED’s etc
a. This will remove the flickering/pulsing as well, and the warnings.
8) Enable all four front headlights for brights and brights flashing
9) Enable angel eye Daytime Running Lights for pre 2007 vehicles
10) Turn on the Xenons with your Trunk Button (10-12 models)
Cluster Related:
1) Enable BMW Efficient Dynamics Display
a. This shows you two arrows in the instrument cluster, and tells you to shift up or down and when to execute the shift for maximum fuel economy. My economy has increased drastically from using it.
2) Turn off the annoying “key in ignition” gong
3) Add the digital velocity to Non-M cars (V=## mph)
4) Add instantaneous digital MPG to M cars
5) Remove the over optimistic correction to the digital speed display
6) Make the low fuel warning come on earlier or later (useful for M cars)
      07-13-2012, 12:14 AM   #9
Big Momma 328i
Drives: 328i
www.bpm-sport.com/Coding.pdf
Remove the dash between bom and sport to go to site where i copied the code options from
Other codes you can do.
      07-13-2012, 07:02 PM   #10
toicy4ya
toicy4ya's Avatar
47
Man, I'm eager to do this but I'm afraid I might mess something up. B
      07-15-2012, 12:27 AM   #11
Big Momma 328i
Drives: 328i
If your doing it yourself just follow the instructions you should be fine lol
      07-16-2012, 08:40 AM   #12
justa3series
Drives: 2010 328xi
I do coding and located in Westchester.
      07-16-2012, 10:30 AM   #13
benzy89
79
Drives: '08 E90 335i
2008 BMW 335i  [7.50]
You both should've PM'd this dude from the start:
      07-16-2012, 01:16 PM   #14
toicy4ya
toicy4ya's Avatar
47
Are you referring to Andrey aka Mofo?
