BMW "Decorator" Valve Caps - Very Bad!
07-10-2007, 07:07 PM | #1 |
Rep 17
Took my e92 to the dealer this afternoon for a 3000 mile oil change. When the car was ready the SA approached me and handed me the four valve caps (the ones with the roundel on them) that I bought a few weeks prior and said he replaced them with the OE valve caps.
When I asked why, he said that with the new TPMS valve stems they've had a major issue with the dissimilar metals of these caps and the stems fusing together. He said they needed to cut the stems off a new 750 just last week because of this. I walked about 30 feet to the parts counter, handed them the caps, and got an immediate credit for my $15.95 plus tax. The obvious question I asked but didn't get a good answer for is "Why do you even sell these caps or, at very least, why don't you advise folks of this issue at the time of purchase since run flats are quickly becoming the norm?" |
07-10-2007, 07:19 PM | #2 |
20
Rep 587
Drives: 2008 135i Vert
Not all cars have TPMS valve stems that have run flats....E90 325i uses wheel speed sensors I believe.
07-10-2007, 07:20 PM | #3 |
418
Rep 12,276
Maybe because they were not aware of the issue. Wouldn't you consider what your SA did a proactive move and an effort to prevent a possible problem for you?
Damn, I thought I was negative. The new TPMS valves are new. Only a few months into production. The decorative stem covers have been around for years. I appreciate you posting this information, as I have the Roundel caps and haven't put them on yet. But your point of view about it is a bit off.
I think it is bad luck to be superstitious |
07-10-2007, 07:26 PM | #4 |
Rep 143
I have a BMW valve cap set, too.
The OEM caps are made of high quality, chrome plated brass. So now I have to go buy cheap Hong Kong plastic ones on eBay? |
07-10-2007, 10:53 PM | #5 |
155
Rep 6,158
07-10-2007, 11:31 PM | #6 |
1469
Rep 3,553
the problem is galvanic corrosion. the aluminum of the TPMS valve stem will react with the brass, which means the brass caps will end up fused to the stem.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
07-11-2007, 06:24 AM | #8 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Thanks for the heads up, guess Ill be removing mine then. However, I thought they were just plastic, didnt feel like metal to me.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
07-11-2007, 06:38 AM | #9 |
54
Rep 340
Well at least no one can steal the fucking things if they are fused to the stems.
E90 330i Monaco Blue, Black Leather, Aluminum Trim, Six Speed, Aluminum Pedals, M-Shifter, Sport Package, Premium Package, Winter Package, Comfort Access, Navigation
Holding a space for Racing Green Lotus Elise |
07-11-2007, 06:40 AM | #10 | |
Rep 143
The Anti-sieze Fix
A little anti-sieze should take care of the unlike metal problem. It works fine on oxygen sensors, sparkplugs and between wheel and the hub. Should do the trick. |
07-11-2007, 07:01 AM | #11 |
31
Rep 746
Drives: 2007 328 Coupe Alpine White
There are new caps, made of plastic, but look the same as the chrome ones. Parts should have told you this. They are called "logo valve caps, abs".
On a side note, I have aluminum caps on mine. They are OE on Lexus, Infiniti, ect. Aluminum caps won't have any issues on aluminum stems. |
07-11-2007, 08:12 AM | #12 |
Klaatu Barada Nikto
30
Rep 1,169
I always put a small dab of Vaseline carefully outside on the threads of the valve before screwing on the metal caps - no problems ever. It acts as both an insulator and a lubricant.
07-11-2007, 08:33 AM | #13 |
Retired
19
Rep 868
Drives: Z4 s30i
If memory serves me correctly the stems on non-run flats also have a brass threaded end. So why do they not seize with the aluminum etc. caps ??
Is this whole thread a hoax ???
M3 GTR - 1/5 scale - 4.2 HP w/ Collari hydraulic brakes - would you believe ~80 MPH on straightaway !! |
07-11-2007, 09:13 AM | #14 | |
Rep 143
Way back, about 25+ years ago when alloy wheels were becomming popular, people were buying polished aluminum caps to match their rims and there were comments (complete with photos) in car magazines at the time warning about how aluminum caps would seize to the brass valve stems. The recomendation back then was to buy stainless steel caps, instead. I haven't heard anything about it for a long time, but I think I should also point out that most of the aftermarket caps, today, are still aluminum. A walk down the isles of your local Pepboys will reveal a wide array of both polished and brightly colored anodized aluminum caps. I personally don't know anyone who has had the caps fuse to the stem and I live in the heavily salted snow belt. Last edited by fer360; 07-11-2007 at 09:15 AM.. Reason: Correct spelling. |
07-11-2007, 09:58 AM | #15 |
95
Rep 1,760
07-11-2007, 11:55 AM | #16 |
Rep 159
They laughed at me about this in Nov 2006...
see post #1 & 5: http://www.e90post.com/forums/showth...ight=valve+cap
Alan(iX)
1988 BMW E30 325iX Ordered 6/29/2006, Built 9/6/2006, Delivered 9/29/2006: 2007 BMW E92 335i Coupe, 6MT, space grey, black leather, dark burl, CWP, ZPP, ZSP, Comfort Access, Nav, Power Rear Sun Shade, Park Distance Control, Sirius |
07-11-2007, 12:25 PM | #17 |
31
Rep 746
I remember that post. But, if you use aluminum caps on aluminum stems, no worries. that is the number one reason dive tanks have to be VIP'd every year. Aluminum tanks are notorious for having a dis-simmilar metal issue(valves are chrome plated brass). That is for you Divers out there, from an Ex-Navy diver. We inspected our own tanks, and you would see it now and then, not a huge issue, as if the tanks are kept full, the air inside is very dry, no moisture. Of course you can't be slapping anti-seize in air tanks!
I personally check my inflation often enough to know with my aluminum caps on the TPMS stems, no issues. Like I stated before that is the way a lot of manufacturers do it. TPMS is on ALL cars now, some have plastic caps, some aluminum. I personally use the aluminum because I don't want to draw attention to my stems. I already have a huge roundel on my center cap. Another side note. You are seeing so many valve cap thefts, not all 4, because kids are putting them on their bikes! That is why you'll see only two missing sometimes! My wifes got stolen off her Mini (British Flags) and I caught the punk a week later, riding his BMX bike with them on. Of course I took them back ASAP. Kid told me BMW, MB, and Porsche were the ones kids wanted, and he liked the british flags!! |
07-11-2007, 12:33 PM | #18 | |
176
Rep 872
I would be extremely happy if my dealership was proactive and did something like that |
07-11-2007, 01:33 PM | #20 | |
1469
Rep 3,553
I had a TPMS system installed on my R that had aluminum stems for my snow tires. i didn't like the aluminum caps that the system came with so i used some OE BMW caps from my 330i (i liked the OE brass BMW caps i bought a bag of 30 and used em on everything for about 5 years). i used a dab of moly grease on the threads. come spring, i had to use a pair of pliers to remove the caps, totally destroying them.
07-11-2007, 01:35 PM | #21 |
Rep 150
07-11-2007, 01:37 PM | #22 | |
418
Rep 12,276
Because.... there are lots of different BMWs with different wheels and tires and valve stems. The new aluminum TPMS stems are only a few months old, and these parts have been around for years. This was basically explained above in this thread...
