Drag Strip in Hot Temps with Slip
07-06-2012, 12:25 PM | #1 |
547
Rep 2,590
Went to the track yesterday in about 85-90 degree temps. DA was about 3500.
I'm fbo with 50/50 meth, I got in 7 runs in 2.5 hours, all times were .2 seconds of each other and all traps were within 1.5 mph. Here is a copy of my best slip. I just don't know what I need to do to break 11s especially since the car feels like its running really strong now. |
07-06-2012, 01:35 PM | #2 |
3077
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
maybe you should run a more aggressive map? what tune are you on?
it's been ages since i've been to the drag strip, but my run was a 12.4@111mph... that was map7 on JB3 (albeit a cool 50 degree night). with the new JB4/Proceed tunes, you can definitely hit even lower 12's high 11's since you're running meth. Hell I'm on Cobb stage2+ agg and i think i can beat my old time (pump, fbo, no meth). I'd say run a more aggressive map and wait till the fall for a glory run. the colder ambient temp will definitely make a difference.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
07-06-2012, 02:15 PM | #3 | |
Hellafunctional
37
Rep 426
Did you log? "It feels like it is running strong" is hard to trouble shoot.
/trololol
Go: Cobb S2+, Big Tom FMIC, CP-E DP & DCI, Royal Muffler, AR OC Turn: TC Kline/Swift SA, Vorshlag Plates, UUC Front Bar, H&R M3 Rear Bar, VAC endlinks & spacers, Forgeline 18x9.5/NT05 265 Square Stop: Endless MX72, Stoptech Rotors/Lines, Motul RBF600 |
07-06-2012, 04:46 PM | #4 |
547
Rep 2,590
Ha I think it was the weather. Most cars were running mid to low 13s. Fastest car there was a 5.0 with ford racing supercharger and its best times were 12.1 so I wasn't far behind.
07-06-2012, 05:34 PM | #5 |
63
Rep 788
U manual or auto?? What u launch at??
Try a 85/15 meth mix.
JB4 Trebila tuned cp-e IC AMS exhaust BMS DCI AR DP's METH RB TURBO
19" VMR VB3 Stoptech BBK TC KLINE VORSHLAG SPEC STG 3 OSS design |
07-08-2012, 05:12 AM | #6 |
25
Rep 699
Drives: e90 335i f30 330i g20 m340i
You have plenty of options:
1) NOSSS 2) strip your interior 3) manually map your boost if you have a piggyback- 12.3 should put you at around 17psi? You can get 19psi out of your stock turbos if 11s mean that much to you. 4) waiting for a colder day will help. 5) e85 mix? Play around with some different things. |
