JRZ RS1 Damper – My Thoughts
06-30-2012, 07:15 PM | #1 |
1567
Rep 4,109
Drives: BMW M3
These are my *initial* thoughts on the JRZ RS1 damper kit. I ordered the following through and had it installed at VAC Motorsports.
These items were added to my existing setup:
Why upgrade springs and dampers? The suspension’s purpose is to keep the tires in proper contact with the road and therefore maximize their grip; the goal of suspension modification is to make the car better at doing that (at least for those of us who value function over form). The springs and dampers are the primary agents responsible for maintaining this contact. The 335i needed more damping force altogether to keep the car settled and quicker to react plus stiffer springs. I found a monotube damper design with high gas pressure would provide faster reaction times than a twin-tube. VAC was more than helpful during the selection process and was ultimately responsible for introducing me to JRZ. Unlike most ‘tuner’ shops, VAC is both a race shop and a machine shop and has an international reputation in high-performance motorsports. The advice I got from them wasn’t marketing fluff or “here’s what the guy with the race exhaust down the street uses”, but drawn from their motorsports experience. I was never shown a product brochure. VAC Motorsports is professional through and through and use JRZ in their race cars. The JRZ RS1 Damper The RS1 is a monotube damper with a large piston rod and 24 clicks of adjustment (one knob controls compression and rebound). It has adjustable gas pressure – a feature very few non-full race dampers have. The RS1 is a powerful damper; it can work with a huge range of spring rates, even very low rates such as stock springs if you’re in a class that requires such. Cheaper dampers are only designed to work with a narrow range of spring rates. Finally the RS1 can be fully rebuilt and re-valved if necessary. It is a damper worth rebuilding. JRZ dampers are well known in European racing circuits. As a matter of fact the RS1 internals are no different than their full racing dampers and are built on the same assembly line. JRZ builds its dampers in the Netherlands. The Driving Experience These are my initial impressions ONLY. I had four 25 minute sessions at NJMP Lightning Raceway on a 100*F+ day; my tires overheated about halfway through each session. I was not able to explore the JRZ setup as much as I wanted. These impressions are an exclusive comparison to the stock springs and dampers. The JRZ dampers’ adjustment knob was set to halfway at all four corners. Handling There is no longer a lack of damping with the JRZs; my brief runs on the track shows they are capable of creating exponentially more force. Their react-and-settle time for transient maneuvers – hitting bumps, turning, acceleration and braking – is immediate. Quick corners slalom turns and lateral acceleration in general is beautifully controlled; the car is poised and ready as soon as the steering wheel is centered. The damping happens so quickly and uneventfully that I had a lot of “wait – we did turn 5 right? I don’t remember it” moments. Yes, the damping is that well executed. Not having to wait for the car to react is one less thing my brain has to process and compensate for. The RS1’s superb reaction times are thanks to many things especially the large piston; it can displace a lot of fluid quickly and its design goes beyond just being a big piston; it has a special tapered shape and … well, I’m not a physics expert. However JRZ figured this out, it works well. This setup loads up in corners with room to spare and holds the car there like it is on rails; it’s a feeling that must be experienced. The stock spring and damper combo by comparison keels over to full compression on one side and stays there; in other words, the damping force is exhausted quickly and the soft springs didn’t help matters. At no point did I approach full compression on the RS1; I always had room in turns. My tires simply lacked the grip to maximize this setup’s power especially given the blistering conditions. I noticed a difference in the 335i’s tendency to ‘squat’; the front end tends to lift up like a speedboat under full acceleration with the stock springs and dampers – it wasn’t pleasant as I had to correct it via steering. It’s gone with the stiffer springs and RS1 combo; the car tracks 100 percent straight and feels rock solid. Nose dive under heavy braking is also better controlled. There is much more resistance and less of a “tip forward” feeling when going from 135MPH on the front straight to 65. Letting off the brakes and going into a turn is more confidence inspiring as well since the JRZ dampers are so much more effective at controlling the forces acting on the car. Ride and Road Feel The ride is referring to the spring’s and damper’s control of the car over bumps. This is high-speed compression and rebound of the damper – transient maneuvers that cause the piston rod to move in excess of a certain velocity (for example, five inches per second). This is opposed to handling which is low speed compression and rebound – the damper’s piston rod doesn’t move as fast when compressing gradually for a turn as it does when hitting a sharp bump. The force created by the damper increases exponentially with the piston velocity and there lies the compromise; a stiff damper with a lot of compression force is great on a smooth track but is going to be unpleasantly rough on the street. Not so with the JRZ RS1. The RS1’s ride is no harsher than stock. The damper curve (a graph of how a damper generates force relative to piston velocity) of the RS1 is such that despite their ability to produce far more force than the stock dampers, the compression and rebound movements have a natural feel. These forces are remarkably well controlled. JRZ’s philosophy is to make the fluid transfers inside the damper body as smooth as possible and those efforts are certainly appreciated here. I don’t have an RS1 dyno but I imagine the damper curve is super smooth. A not-so-good damper by contrast will have a rougher graph – inconsistency, in other words. Continuing, the ride is also more compliant thanks to almost infinitely better reaction times. Thinking of the road surface as a book, this setup reads it word for word including the punctuation marks without adding opinions or paraphrasing. Just the facts, ma’am. JRZ from experience concentrates R&D on the small compression movements – these comprise the majority of damper travel movements. Going over small bumps, cracks in the road, tar strips, and even highway rumble strips is effortless; bumps will happen and they’re over just as fast. The chassis feels “alive” and in sync with the road surface. This was a strange sensation at first. Previously I was only getting communication through the steering wheel and “oh that must have been a bump” from the chassis. It’s reassuring to know what’s going on under your car as it happens. Wrap-up I’m pleased with what the JRZ dampers and AC Schnitzer sport springs have done for my 335i. Had I known the difference they would make I’d have done them initially instead of other items (control arms and so on). Good dampers and springs made 80%+ of the overall difference versus stock. I have some Michelin PSS on order which should let me explore the setup a bit further. I'll probably end up posting a new thread later on with updated thoughts/impressions.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT Last edited by CJ421; 06-30-2012 at 09:23 PM.. |
06-30-2012, 08:35 PM | #2 |
102
Rep 1,903
Drives: e92 335i 6MT
Thanks for the write up! I can only imagine what these dampers feel like
06-30-2012, 08:55 PM | #3 |
boku no namae ha...
336
Rep 11,025
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
nice
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
06-30-2012, 11:00 PM | #4 |
92
Rep 1,324
Drives: 335i Coupe, 6 Speed
Because
Racecar Great write up! now for some comparison testing... |
07-01-2012, 10:20 AM | #5 |
2006 330i, TSM, Black, manual, sport
880
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
Because
Racecar 2! Great review!!! Can everyone tell he's an engineer?
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
07-01-2012, 10:33 AM | #6 |
164
Rep 2,556
Very What is adjustable with rebound: low speed or high speed compression? Does the car move around alot more over undulating surfaces on the highway? That's my only complaint about Koni sports.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
07-01-2012, 03:12 PM | #7 | |||
1567
Rep 4,109
Drives: BMW M3
You mean like a washboard surface? I did a 2-hr cruise yesterday on the highway and went over a surface like that. With the stock 335i springs/dampers I could feel the car moving up and down sort of like a trampoline. With the JRZs ... felt nothing at all. If I didn't drive over that road before I wouldn't have known it was a washboard surface (aside from seeing other cars bouncing up and down ). I could not wipe the smile off my face afterwards.
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
07-01-2012, 05:06 PM | #8 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
great writeup
gotta love that "function over form" thing |
07-02-2012, 05:02 PM | #9 |
just another bmw douche bag
195
Rep 3,640
sounds like a typical single adjustable system using a needle valve, except for the gas pressure adjustment. so is the adjustment for gas pressure completely separate? And does that only affect compression? There is no remote reservoir on these, right?
07-02-2012, 10:08 PM | #10 |
164
Rep 2,556
How often does JRZ recommend you service these dampers? I've read some high end dampers have frequent service intervals.
Also, why did you go with M3 springs instead of 335i? That's why your ride height is what it is.
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS Last edited by cvc 22349a; 07-02-2012 at 10:12 PM.. Reason: add |
07-02-2012, 10:39 PM | #11 | ||
1567
Rep 4,109
Drives: BMW M3
Thanks for the comments.
Regarding the gas pressure, I don't actually know. The RS1 is brand new as of a few months ago and JRZ hasn't released any in-depth technical info on it. The gas pressure is adjusted via the little metal nub sticking out the side of the damper body (can see it in my photos). I don't see how changing the gas pressure would affect compression but not rebound (or vice versa). It's a little outside of my knowledge level right now. JRZ's brochure does a good job of explaining their philosophy behind using gas pressure in the damper: http://www.jrzsuspension.com/Downloa...atalog2010.pdf Quote:
Service interval - again something I'll have to check on. The RS1 is new. BTW I got my Michelin PSS on order; next time I go to the track, I'll be back with a vengeance. I went for a drive tonight and on the street this setup feels almost wasteful. It is unbelievable to drive. Never even remotely harsh yet totally communicative and insanely responsive. I went over a few hilly roads and where I'd get that floaty feeling with stock shocks, the JRZ hold the car to the ground like glue. It's strange at first. I love it.
07-03-2012, 11:55 AM | #12 |
261
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
Looking to hear your impressions with the PSS tires. I went from the same Hankooks to the PSS, and it was and awesome upgrade. They are much quieter and more comfortable and after about 500 miles the initial tread squirm and greasy feeling fades away and leaves you with a near r comp level of grip.
07-03-2012, 02:13 PM | #13 | |
1567
Rep 4,109
Drives: BMW M3
07-03-2012, 05:43 PM | #14 |
92
Rep 1,324
07-03-2012, 11:13 PM | #15 |
1567
Rep 4,109
Drives: BMW M3
That is the plan!!
AST 5300 w/ remote reservoirs ... gonna be interesting.
07-04-2012, 12:36 AM | #16 |
Supreme Allied Commander
3888
Rep 54,538
Drives: F80 M3
This is one of the most detailed review on a coilover suspension I have read to date.
This review makes me want to give these a try just to see how wonderful the JRZ RS1 really is. |
07-04-2012, 10:03 PM | #17 |
1567
Rep 4,109
Drives: BMW M3
Thanks Harold. If you're ever in the Philly area let me know.
07-06-2012, 11:56 AM | #19 |
3888
Rep 54,538
Drives: F80 M3
07-07-2012, 10:25 AM | #20 |
Rep 103
Drives: 2005 X3; 2010 335i M Sport; 20
great review.... u gonna love PSS!
07-09-2012, 10:15 AM | #21 |
314
Rep 2,448
07-10-2012, 09:56 PM | #22 |
1567
Rep 4,109
Drives: BMW M3
You can get the RS1s with adjustable collars as Harold noted. That would give you adjustable height independent of the spring. My setup by comparison is dependent on the springs for ride height. As far as spring recommendations ... the ACS ones are the only ones I've heard of being recommended with this damper. Though I don't see why you could not use a standard spec 335 or M3 spring. I forget the exact reasoning why I don't have 335 springs in the front, just that they did not work. The rear is M3 because it's an M3 style shock and I have the M3 lower rear camber links.
These JRZ dampers are quite different because the they are designed to compensate for the spring and act in ways you would not expect of a damper. It's still important to choose the right spring (the key number is the spring rate you want); just realize a JRZ damper is far more effective than a 'normal' damper. I am still wrapping my head around the behavior of these dampers; since getting them installed I now understand things I could not have understood reading a book (which is what I've been doing for months). I'm usually not fascinated by things but am overwhelmed by the capabilities and sheer power of these dampers (and how utterly controlled it is). I wish I could explain better but I think it must be felt. I'm calling it magic for now. Now I'm not going to stare at your tires at every meet. Regarding ride height - my car has settled a tiny bit. Can't tell in a picture but it's lower. Going out of my driveway I slightly scrape the air deflector things under the front bumper. That did not happen initially. Here is what the car looks like, almost like factory with a slight rake towards the front. The stance is visibly different in person.
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT Last edited by CJ421; 07-10-2012 at 10:29 PM.. |
Tags |
jrz |
