The Tire Rack
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Turbo Engine / Drivetrain / Exhaust Parts > FS: iCarbon n55 catted downpipe (thermal coated)
      06-27-2012, 10:33 PM   #1
parky1215
parky1215's Avatar
564
Drives: F90 M5C | G06 X6 M60i
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
*** SOLD ***
N55 iCarbon downpipe with High Flow Cat + Black ceramic coat
Fits both N55 135i and 335i (no X-drive)
Used for: Approximately 1yr, 10k miles.
Price: $395 shipped
Note: Gaskets are not included. You can either re-use stock or buy new from
http://hpashop.com/ar-design-BMW-Bom...bproofGSKT.htm
Note: This dp will get you great performance boost while reducing smell associated with catless dp.
However, you will need BMS CAN tool or tune to get rid of SES light.
Features
* Eliminates the overly bulky and highly restrictive OEM N55 downpipe
* 16-25 RWHP and 17-26 WTQ gains on an all stock car over the entire PowerBand!
* Gets rid of power-robbing crush bends and small tube diameter
* TIG-Welded for superior quality and strength of all welds
* Features an ultra-smooth pipe designed for reduced exhaust-turbulence
* PPD (Proprietary Piping Diameter) step sections create max power output, while allowing seamless connectivity with OEM and aftermarket exhausts
* Increased throttle response and quicker turbo spool w/ less required engine effort
* 150% GUARANTEED fitment due to extensive R&D on the N55 Motor for over 8 months
* Piping diameter goes from 101mm (4") to 76mm (3") and the DP has 1.5mm walls.
* FULL T-304 Stainless Steel construction for oxidation resistance, added durability, and heat resistance
* Fits both 135 and 335i with the N55 egine
* Mounts to all factory locations, and has adequate fittings for 02 sensors and OEM monitoring units
* Installs in under 3 hours for DIYers and under 2 hours for professional installation.
Let me know if you have any question.
      06-28-2012, 04:03 AM   #2
gustnyc
gustnyc's Avatar
21
Drives: 2011 E90 BSM 335 xdrive
Even though it's catted it'll throw a ses light? Then I wouldn't be able to pass inspection right? I have a jb4 with auto clear but I have inspection in a few months.. Just debating whether I want to go Catless or not..
2011 BSM E90 335 xdrive, msport,performance package,nav,premium,cold weather,ets cp,bms intake,custom exhaust,jb4 stage 2
R.I.P. 09 BSM E90 335 xdrive =*(
      06-28-2012, 11:11 AM   #3
parky1215
parky1215's Avatar
564
That's correct. Since it's high flow cat, it does not meet emission requirement and BMW software will detect it as if there is problem with cat.
Benefit of high flow cat is that you still gain great power from factory downpipe and you don't have to deal with stinky smell produced from catless downpipe.
      07-15-2012, 12:46 PM   #4
parky1215
parky1215's Avatar
564
price reduced
      07-29-2012, 10:20 PM   #5
parky1215
parky1215's Avatar
564
bump
