Dension Gateway 500 working in E90
07-08-2007, 06:17 PM | #1 |
Rep 38
I installed a Gateway 500 in my E90 March 05, Professional, I-Drive.
It failed to work with the 2.02 MOST firmware on their website but does work perfectly now with a BMW specific firmware which is currently beta but should be downloadable soon. The official firmware should be fine for most cars but the beta one is for older ones like mine. If anyone else is having trouble I can email the right firmware. I'm impressed with it so far. If an Ipod is connected one can choose between browsing on the Ipod or on the Nav screen. The layout on the Nav screen is like that on the Ipod - Artists, Albums etc and the use of the I-drive controller mirrors the use of an Ipod click wheel. Also there's a handy ABC search facility. If a USB device is attached there's a similar facility plus direct browser navigating - the same as if browsing an MP3 CD with i-drive. There is a delay when the USB device is first connected because it needs to build a database. I have suggested that they make a PC utility to build this database before connection. Artist/Album/Track is shown from ID3 tags when playing mp3's. I'll post some pictures in a few days. Also, I'll be testing it soon with a large hard drive to see how responsive it can be. It's no slower with an 80 GB Ipod than the system is with an MP3 cd and so I'm cautiously optimistic it can handle a 250GB hardrive. |
07-09-2007, 04:49 PM | #4 | |
Rep 38
I'll post some photographs on Wednesday - I'm away from home until then and do not have my camera with me. |
07-12-2007, 12:07 PM | #5 |
Rep 38
Okay here's some pictures:
I installed it just behind the cd changer: At the moment I've just put my ipod in the tray above, there's also a clip which I'm not using: First you select the source (Aux in to GW500, Ipod or USB): Ipod GW is control via I drive rather than the ipod itself which is Ipod UI: Thereafter, navigation is the same as on an Ipod, the I drive wheel replicates the Ipod wheel. Note also that it is possible to search Albums or Artists: Navigation via USB is the same except there is also folder navigation. I'll test it with a 250 GB hard drive at the weekend - I need to sort out a power supply for it first though. The sound is digital via MOST unlike the 6FL. Also there is no battery drain issue on the Ipod. It's very responsive on my 80GB Ipod (same speed as an MP3 CD in the dash.) I would recommend it without reservation but you will need either a CD changer fitted or a car coded by the dealer to accept a CD changer. |
07-12-2007, 01:13 PM | #8 | |
Rep 38
This is an extremely minor issue which I suspect will be remedied in a firmware update for the GW500. |
07-12-2007, 01:26 PM | #9 |
Rep 3
how much was the unit? and was it easy to install or did you have it done at a shop. also any chance you could show a picture as to where the other end of the cable on the module goes into?
07-12-2007, 01:57 PM | #10 | |
Rep 38
The cables on the module that you see in the first photograph are not connected to the car - one is to an RCA and bypass switch to reconnect the CD changer, one to the Ipod and the other is a USB extension lead. You have to disconnect the fibre optic cable on the MOST ring with the light coming out of the CDC and connect this to a plug that goes into the module. I couldn't photograph this without removing it again. You also need a power source (non-switched +12v and ground - you can tap into the cd changer's or the amp's power supply. Full instructions are here: http://support.dension.com/downloads...2007.06.25.pdf The E60 diagram applies to the E90 too. As long as you're confident tapping into a cable for power it's OK to install. Otherwise it would take a HiFi installer about 20 - 30 mins. IMPORTANT UPDATE: When I installed it I followed the E60/E61 instructions. The new installation manual http://support.dension.com/downloads...2007.06.25.pdf has instructions for the E90 and says that it is the input fibre optic cable to the CDC that should be used (i.e. opposite to the E60 instructions I used.) This may explain why when my USB hard drive had insufficient power to spin up the CDC came back online. I can't be bothered to reverse it now but will do so if any other problem emerges. FURTHER UPDATE I have tried the new E90 instructions but these do not work for me - the CDC stays online constantly. I have reverted to the E60 instructions. Shanmand, however, had the opposite experience. I suspect that there are hardware and possibly software differences which depend upon the build date of the car. I would therefore recommend trying it both ways - the cables can be reversed easily. Last edited by Jackdaw; 08-09-2007 at 07:38 AM.. |
07-12-2007, 02:30 PM | #11 |
Retired
19
Rep 868
Drives: Z4 s30i
Can you do video on the NAv screen ???
M3 GTR - 1/5 scale - 4.2 HP w/ Collari hydraulic brakes - would you believe ~80 MPH on straightaway !! |
07-13-2007, 03:23 PM | #12 |
Pisco
Rep 25
This is great info. I knew some will come out with a better version of the BMW solution. Will this work with E90 Professional Nav System?, Does anyone know where to get this in the USA?
07-13-2007, 04:49 PM | #13 | |||
Rep 38
I would check with Dension whether there are any material differences between USA and European BMW vehicle software coding. |
07-17-2007, 10:16 PM | #14 |
156
Rep 1,014
Wow! Very interesting. Wonder who will be the first US guinea pig, as in will the US software be compatible? Let's try to get some info from Dension.
Why do all the pics show at the bottom CD5? And after CD5, what are 001, 006? Must have something to do with needing the car coded for a CD changer. Wonder if US dealers will do the install and about warranty issues. edit: Just looked at Dension website; only small box mentioning BMW and Mini. Mostly MB, Audi, Porsche (considering it for our Cayenne) edit2: Don't see any BMW after 2005 on the compatibility list at Dension.
///M4 'vert
07-18-2007, 04:01 PM | #15 | ||
Rep 38
The distributor in the link above supplies the USA and Canada and so they ought to know whether it is compatible with North American cars. Quote:
I'm not going to have time until next week to test a 250 GB hard drive - I've been too busy at work to sort out a power supply. |
07-18-2007, 05:28 PM | #16 |
General
539
Rep 18,123
Interesting. I might have to get this after someone in the states does a write up.
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
07-20-2007, 11:48 AM | #17 |
Rep 79
Great write up! Thanks for the info. I contacted Denison after purchasing my e90 almost 2 years ago. The Gateway 500 has been in development a long time. Seems like it was worth the wait.
I do not have a CD changer in my car. So I guess that means taking the car in for coding after the installation. Not sure how the dealer will react to that request. Can't wait for someone in the US to get this installed.
E90 330I/Sapphire Black/Black/Sport/Premium/Nav/Blacklines
07-20-2007, 06:57 PM | #19 |
Pisco
Rep 25
I just called Dension in Canada and they said that the Gateway 500 is $549.00 and $40.00 shipping charge to California, you could ask for Harry for info. (905) 764-9533.
The only thing is how to get you E90 ready for CD changer so the Gateway 500 will work. I do not know where to go here in Northern California (South Bay Area) to get this update, the BMW dealers will just laugh at me if I request this from them. Any ideas here? |
07-23-2007, 01:56 PM | #20 | |
Rep 79
It is not uncommon for someone to install a CD changer themselves. So, would it not be possible to ask the dealer to code your car PRIOR to the installation. Maybe someone who is a BMW technician could confirm that it's possible to code a car PRIOR to installing the CD changer (or Gateway 500).
07-23-2007, 07:36 PM | #21 |
1577
Rep 3,888
07-26-2007, 12:11 PM | #22 | |
10
Rep 264
Let us know when you try out the 250GB Hard drive... if this works I will definately buy it. |
