Coolant expansion tank replacement?
06-20-2012, 03:10 PM | #1 |
25
Rep 167
Hi, I'm planning to replace my waterpump + ts as part of preventative maintanance. Do I need to replace the expansion tank too? I'm at 134K.
Thanks |
06-20-2012, 03:17 PM | #2 |
138
Rep 2,731
You don't have to. You could replace that shitty little plastic vent screw on it though, mine cracked and leaked.
If the tank failed later, it would only leak and go into limp mode. If your waterpump had failed catastrophically, I suppose we could argue that the tank may have been stressed by overheating pressure as a result and could be weakened prematurely. But you are talking about doing preventative maintenance so I am assuming your pump and stat are both working still (just changing them for peace of mind and to save a hassle later). |
06-20-2012, 04:54 PM | #3 | |
25
Rep 167
I figure it makes sense based on the mileage of the car and also my upcoming roadtrip to Vegas..(hot weather & desert heat) |
