F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW M Performance OEM Carbon Mirror Caps - Install DIY and Photos
GetBMWParts
      06-20-2012, 01:17 PM   #1
GTM_Challenge
GTM_Challenge's Avatar
272
Drives: E46 M3, E90 M3
BMW M Performance OEM Carbon Mirror Caps - Install and Photos
BMW's OEM carbon is always top notch and their new carbon mirror caps for the F30/F20 are no different. Full carbon custruction with an OEM plastic bracket epoxied to the back side so it can mount as close to factory as possible. Their isnt much weight savings, but this is primarily a style part anyway. It does the job well. We had these on order for stock for some time, and they just came in this week.
These were a little different than the usual E9X ones we had done where they replicated all the oem clips in plastic and it was simple snap out, snap in process. These F30 ones require a little more work and the OEM instructions are extremely limited.
Since we offer these to our customers i thought it was a good idea to do a step by step photo shoot of the install and some breif instuctions. Enjoy!
Grab and pull the oem cap off starting from the top edge, then pull straight out
Tilt the mirror lense up as much as possible, then using a plastic panel tool or similar pull the lense outware at a slight upward motion
Youll see the wires for the mirror lense/heating element. They do not need to be unclipped if you rest it on the window sil
3 tabs that are located where the oem cap clips in
Push in and break off the 3 tabs
Put the mirror cap on the front side making sure it rests in the little catches
New holes for the mounting screws and washers to go into
3 bolts, 3 washers
Fasten til snug with a torx driver
Installed hardware, clip mirror back in so that its orientated with the plastic receivers
Front finished view
Side finished view
Look for more installs and details on BMW M Performance parts an others!
Appreciate 3
      06-20-2012, 06:10 PM   #2
svache
svache's Avatar
267
Drives: 2012 F30 328i
looks great, thanks for the DIY
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread
      06-27-2012, 04:25 PM   #3
GTM_Challenge
272
Performance steering wheel write up is next
      06-27-2012, 08:09 PM   #4
m5 guy
m5 guy's Avatar
1692
Drives: 2020 M5 Comp
Those mirror caps are definitely growing on me. I think the fact that the rest of the mirror is black and not body colored is what makes it work.
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      07-31-2012, 01:54 AM   #5
awhk
No_Country
88
Drives: 2023 iX M60 SBM
So you cannot revert back to original mirror covers as the tabs are broken?
      07-31-2012, 09:43 AM   #6
GTM_Challenge
272
You are able to go back to the originals, the tabs removed wont affect the OE cap staying on.
      09-17-2012, 07:00 PM   #7
Sock_Puppet
Sock_Puppet's Avatar
Drives: 2013 328i
Very nice. Thanks for the pics.
      09-18-2012, 07:20 PM   #8
shutterlife
10
Drives: F30 M Sport AW
Just did these, it's easier to remove mirrors first and then locate the cap tabs to remove the caps.
Also, the mirrors required a little bit of force to remove. Definitely made me scared I would break the mirrors.
I didn't have a plastic pry bar, tried using finger, did not work. Finally found a wide thin flat piece of metal. Which I covered with a microfiber cloth and rubber glove to use.
Wish I had pictures. But didn't think about it.
Hope this helps anyone with second thoughts on doing it yourself.
Appreciate 2
      09-18-2012, 09:45 PM   #9
Messer-schmitt
Messer-schmitt's Avatar
Drives: 2012 BMW 328i
...I think I just found my first mod...
      09-18-2012, 10:20 PM   #10
GTM_Challenge
272
We have these in stock here at the shop if looking for a set
      09-24-2012, 11:57 PM   #11
Pandarakus
I'm curious what actually is holding the OE cap.. Is it just glue? How come you could just pull it off?
      09-25-2012, 10:01 AM   #12
GTM_Challenge
272
There are small plastic clips that hold the original one in place. You can break them free by simply using enough force.
      09-25-2012, 07:05 PM   #13
Pandarakus
If we break the clips of the original, how is it possible for us to revert back to it?
      09-25-2012, 07:31 PM   #14
GTM_Challenge
272
the part you break off doesnt effect how the oem clips grab. The oem caps can go right back on
      09-26-2012, 06:26 PM   #15
shutterlife
10
Confirming as well that you can revert back. As the clips for the original caps use the square holes as opposed to being screwed on.
      03-02-2013, 01:14 PM   #16
jtuds
71
Drives: 335rwd Dinan S2
If the OEM caps can go right back on, what it the point of the tabs you break?
Also, how did you get the original OEM cap off in step 1? Like does it literally just come off by pulling it?
      03-02-2013, 09:41 PM   #17
minijet
minijet's Avatar
Australia
45
Drives: Train
you break those tabs so you can screw on the cf caps. the OE caps dont screw on they only hold onto mirror frame via some tiny clips on the circumference of the mirror.
Yes you just pull starting from the top and it comes right off.
      03-03-2013, 04:43 PM   #18
jtuds
71
makes you wonder why the tabs on the inside are there at all
      03-27-2013, 09:48 AM   #19
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Maybe i am being a little thick, but when you remove the original caps you aren't actually "breaking" any tabs, correct?
Yes it very much does! And why the CF caps couldnt just be molded in the same form as the stock caps and snap into the same perimeter tabs - something to do with the strength/brittleness of the CF squeezing into the pre-existing tabs maybe?
Current: 2021 340xi
Retired:
2018 330xi | 2016 340i 6MT | 2013 335i 6MT |
2011 328i 6MT (N52) | 2008 335xi (N54)
      03-29-2013, 12:47 AM   #20
kon
Singapore
21
Drives: F30 310i > G20 310i
Just got hold a pair of these mirror cap, but they seems to only have 2 holes, instead of 3 now... production date indicate w26/12 (i assume week 26th 2012)... hmmm
      04-08-2013, 07:34 PM   #21
jtuds
71
have you installed them yet??
      04-08-2013, 08:31 PM   #22
kon
Singapore
21
It turned out the parts were wrong - they were correct part number per ETK, but physically (the shape) they were wrong, so are waiting for the new one to arrive
f30post
