I'm disappointed with the Comfort Access system.
07-05-2007, 01:21 PM | #1 |
137
Rep 1,914
The principle is great, I only wished that mine worked as advertised. It seems that at least 50% of the time, I have to pull the door latch twice to get the door to open even if I go slow. When I touch the ribbed area to lock the door it sometimes takes 3-5 secs for the door to lock. The trunk is the worst. I grab the latch and most of the time nothing happens for at least 5 secs or more. I keep grabbing the latch, but to no avail. I guess I could just forget about the CA and just use the fob. Am I the only one with this issue?
07-05-2007, 01:23 PM | #2 |
AC
95
Rep 2,387
Didn't the sales person told you, you have to pull the door latch twice.
I did not get the CA, but my sales person was kind enough to educate me on how the system works. Afterwards, I decided to use the money to get other options.
Your Supreme Leader
07-05-2007, 01:26 PM | #3 | |
29
Rep 2,134
...may need to recharge the battery by riding with same in the ignition for a few. Retry it then. I had the same issues until I recharged it. Good luck.
2007 E92 335i Coupe: Monaco Blue/Premium/Sports/Winter Package/Nav/CA/6MT/TT/Active Cruise/Active Steering/iPod/Rear Shade/Tint/Short Shifter/OEM Alum Pedals//
07-05-2007, 01:30 PM | #4 |
Now With 33% MORE Sarcasm Free!
157
Rep 3,462
Battery doesn't charge in the car with CA.
A BMW is Just a Car, it doesn't make you smart, handsome, clever, better, cool, or wealthy. |
07-05-2007, 01:30 PM | #5 | |
274
Rep 6,510
07-05-2007, 01:31 PM | #6 |
95
Rep 1,614
I thought the comfort access fob was non-rechargeable?
2019 G05 40i (premium excellence, m-sport, 2VR), Tesla Model S 100D, Nissan Leaf SL
Volvo XC90 T8, Subaru Outback, E84 X1 28i, E91 328i xdrive, 6MT, VW Touareg TDI, E90 330i, E46 325iT, MINI Cooper S (all retired) |
07-05-2007, 01:32 PM | #7 |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
07-05-2007, 01:33 PM | #8 | |
157
Rep 3,462
It works 100% of the time if you just slow down 1/2 second. Seriously, or just get used to pulling the handle twice to open the door. Initially I was a little "WHAT?" with the function of CA, then after using for a little while I have learned to just give the German electronics a split second to respond appropriately. OR You can just stay pissed off at what is really a great feature. Give it just that split second...
07-05-2007, 01:37 PM | #9 |
95
Rep 1,614
I do love CA (I'd find the 'insert fob then press Start' a little annoying), but I still wish it worked on the rear doors on the E90 as it does on the 5 and 7 series.
07-05-2007, 01:40 PM | #10 |
601
Rep 6,750
You don't even have to touch the car or the handle to unlock the doors. Just slide your hand in between the handle and the body of the car, and it should unlock. It seems to detect the moisture (?) or anything conductive. When washing the car, it will unlock or lock your door by simply spraying water on the handle (with the keyfob nearby of course).
Funny how sometimes if the car does not unlock, I take my hand out and put the other one by the handle. |
07-05-2007, 01:45 PM | #11 |
General
355
Rep 18,218
You also have to hold the trunk button to make it work correctly. It is not just a push and trunk opens, its hold and then it will unlock.
FYI the CA keyfob does not charge it has a replacable battery.
07-05-2007, 01:46 PM | #13 |
Rep 11
I've found with the trunk, it works best when you grab the trunk handle and actually squeeze it instead of just holding it. It should unlock it immediately.
07-05-2007, 02:16 PM | #17 |
2753
Rep 4,445
Yeah, I believe the battery is not a rechargeable battery.
07-05-2007, 02:21 PM | #18 | |
156
Rep 10,411
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
07-05-2007, 02:29 PM | #19 |
95
Rep 1,760
locking kind of sucks since your usually walking away from your door at the same time your closing it (which makes not walking away and standing by it in order to press the button suck)
but when i do stand there it locks right away as for unlocking it usually unlocks when i put my hand on the handle before i can even pull, if it doesnt i just pull twice in quick succession and it works as for the trunk, never had a problem at all |
07-05-2007, 02:30 PM | #20 |
536
Rep 4,021
Drives: 2008 335xi Coupe
Read This Thread
From the M5board......
http://www.m5board.com/vbulletin/showthread.php?t=99109 The best part about CA is having the key in your pocket all the time. No fumbling around, no scratches on the steering column or dash from dangling keys. The bad part about CA is losing a key or misplacing it....(read the thread above and see where the key was).....
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
07-05-2007, 02:32 PM | #21 | |
137
Rep 1,914
07-05-2007, 02:34 PM | #22 |
137
Rep 1,914
