Airbag module flush with steering wheel cover?
07-03-2007, 01:18 AM | #1 |
37
Rep 69
I have a rather anal question:
Does your airbag module sit flush with the steering wheel cover? That is, do the parts 3 and 7 in the diagram below mate perfectly or is there a small gap between them? The reason I ask is that I had my steering column replaced because of the infamous ELV malfunction, and the dealer disassembled and reassembled my steering wheel. My wife thinks that there was no gap between the airbag module and the wheel cover, but now there is - about 3 mm. Could someone check his or her steering wheel? By the way, I have the sport steering wheel (not the non-sport package wheel) as shown below. TIA. |
07-03-2007, 09:41 AM | #2 |
Smiling politely
165
Rep 7,931
Surprised nobody has answered this yet, it's such an easy question.
I'll try to remember to check during lunch. Off the top of my head, I think mine may have a very slight gap, but less than 1mm. 3mm sounds like a lot! If no one responds, you can always go by the dealer (if it is close enough to you) and peek at the other cars on the lot. Then you'd be right there to have them fix it if it's not right.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
07-03-2007, 09:46 AM | #3 |
550
Rep 6,563
No gaps. If the gap is big enuf for you to notice it and it appears that it also bother you, then the installation is not correct. have them fix it. I like BK idea as well. If not too much trouble, go to dealer and see what other car on their lot looks like. It would help as all out too if you had taken a photo of this 3 mm gap you are talking about. I am not good at metric.
under construction! |
07-03-2007, 09:52 AM | #4 | |
pull my finger to get your kinder® surprise
148
Rep 10,455
3mm is about 1/8 inches
there is a gap on mine, I would say about 2mm. I really don't see they screwing up the install as the airbag needs to be clipped in, so either you get a REALLY BIG gap (way more than 3mm that's for sure) or a tiny gap Quote:
07-03-2007, 09:59 AM | #5 |
Rep 115
Mine is 2 to 3mm gap between parts 3 and 7. I assume its because the horn requires some play when you push on part #3.
My selection of 'tape measures' kept me from being precise, its probably closer to 2mm.
Ordered: 4/1/07, Picked up 5/20, e92/328i, Deep Green, Saddle, Lt. Poplar, ZSP, ZPP, Step, Nav, Logic 7, CA, PRS, PDC, 6FL Ipod, Sirius
07-03-2007, 10:13 AM | #6 |
148
Rep 10,455
that's what I figured as well, otherwise, you woulldn't be able to press on the horn, but like you said, my measurement was just off the top of my head, it's 2 to 3 mm gap, point to the OP is, your steering wheel should be fine, if you're really worried, post up a pic so we can compare it to our car
07-03-2007, 10:41 AM | #7 |
Rep 115
Best I could get (it's early).
07-03-2007, 11:36 AM | #9 |
Rep 115
Hope the OP is seeing the same thing and has no problem.
07-03-2007, 12:01 PM | #10 |
37
Rep 69
e92sam,
Thank you for the photo. My gap definitely looks a lot larger. If the airbag is just clipped on, maybe I should try pushing it in further. Thanks for your help everyone! I need to go back to the dealer for other things, so I'll check out the other e90s then. |
07-03-2007, 11:49 PM | #11 |
Smiling politely
165
Rep 7,931
I forgot to check the gap on my steering wheel during lunch, but I did check it on my way home tonight. It's a bit larger gap on my wheel than in e92sam's photo, so I bet yours is fine. Do have a look at other cars while you're there, though, for peace of mind.
07-04-2007, 08:22 AM | #12 |
148
Rep 10,455
the gap on mine is a bit larger as well, can you take a pic? I'll take a pic of mine to compare
07-04-2007, 08:25 AM | #13 |
Perf BMW mag issue 147, 159
414
Rep 6,803
If you made it home and the airbag hasnt fallen in your lap yet than I would assume its in place correctly There are a few springs behind that airbag which give it play for the horn to function. Its normal.
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
07-04-2007, 10:33 AM | #15 |
148
Rep 10,455
I KNOW, same feeling, I thought my was all good and dandy until I saw e92sam's photo, damn you e92sam
poiney, would you mind snapping a pic of yours for comparison?
07-04-2007, 12:51 PM | #16 |
Smiling politely
165
Rep 7,931
I'll go do it right now (serious)... hold on.
07-04-2007, 12:54 PM | #17 |
148
Rep 10,455
cool, I'll take a pic of my steering wheel later tonight as well!
07-04-2007, 01:24 PM | #18 |
Smiling politely
165
Rep 7,931
Okay, here are some photos. As you can see, if you look at it from the right angle, you can see a gap, which is bigger than I thought. From the front or at less of an angle, you can't really see it. I bet the OP's is normal.
07-04-2007, 01:26 PM | #19 |
148
Rep 10,455
wow BK, your photos are really nice! they look very professional.
K, no need for pictures of my steering wheel then, mine's the same as yours, if you look at it from the side, you see a bit of a gap, but at other angles, not so much
07-04-2007, 01:35 PM | #20 |
Smiling politely
165
Rep 7,931
LOL, thanks. With my BMW-induced obsessive compulsive disorder, I notice a few specks of dust on my wheel in the shots... have to do an interior cleaning soon.
07-04-2007, 01:39 PM | #21 |
148
Rep 10,455
your photos have relieved my temporary OCD on my steering wheel
now I can relax and work
07-04-2007, 05:18 PM | #22 | |
36
Rep 798
looks like the photo below. I measured it accurately. The gap around the sides (and bottom) ~ 3 mm, if I measure the gap with the ruler parallel to the steering wheel column (i.e., normal to the face of steering wheel). The gap on the top (that looks largest) ~ 4 mm, if I also measure the gap with the ruler spanning the gap (i.e., the ruler is still fairly parallel to steering wheel column). |
