      06-04-2012, 08:41 PM   #1
Alekshop
Alekshop's Avatar
435
Drives: E30 M3 l E46 M3 l GT4 l 991 RS
✪ Alekshop | JRZ RS Pro 1M Adjustable Coilover Kit
JRZ Suspension Engineering offers one of the best high performance club sport damper available today. Combining the best aspects of JRZ RS and 2-way racing damper, the JRZ RS Pro gives the owner ultimate suspension tuning ability while maintaining compliance for driving on public roads.
The design of the JRZ RS Pro takes your car to the next level. Stiffer cars with higher levels of power demand the control JRZ can supply.
With the control of gas pressure charge as well and compression and rebound adjustments, the JRZ RS Pro will get the most out of your high performance car.
Features:
  • 22 mm rod strut, 16 mm rod damper
  • 12 clicks of compression
  • 24 clicks of rebound
  • Adjustable gas pressure, mono tube
  • Piston designed for high performance
  • Large adjustment range
  • Available quick disconnect fittings
  • Remote reservoir or piggyback canister
Benefits:
  • Better chassis control for higher rate springs/power/ratio
  • Street ride, racing performance
  • Easy to change configurations
Springs:
Can be purchased with Eibach or Swift springs with custom spring rates
Camber/Caster Plates:
  • Available with Vorshlag Camber/Caster Plates
  • Available with Ground Control Camber/Caster Plates
Being JRZ Suspension Engineering Authorized Dealer we carry full line of JRZ products (RS, RS1, RS Pro, Triple Adjustable, etc.)
Vorshlag Camber Plates:
Ground Control Plates:
To place your order or to get more information please give us a call ✆ 925.609.4559 or send us an e-mail ✉ info@alekshop.com
Aleks.
Search this Thread:
Advanced Search
1addicts
