Leaky roof on my E93 335
07-02-2007, 12:17 AM | #1 |
22
Rep 528
Big rainstorm in toronto a couple weeks ago. My roof was leaking.
They replaced the seal, they say no more leaking. There was a 328 E93 in the shop for a leak at the identical spot. Any other E93's out there have a leak>
E92 335
SPACE GRAY/BLK; 6MT; PREMIUM 19" SPORT PACKAGE;6FL;COMFORT ACCESS |
07-02-2007, 12:21 AM | #2 |
¡Viva España!
373
Rep 7,803
Another one, not good.
23 G42 230i Mineral White Cognac, Aluminum With Mesh Effect Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
07-02-2007, 07:19 AM | #3 |
418
Rep 12,276
This is probably pretty common. I remember American cars always had problems with T-top roofs leaking the first production year... until they figured out where the seals needed to be improved.
I think it is bad luck to be superstitious |
07-02-2007, 07:27 AM | #4 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
where was the leak coming from - will keep an eye on mine (when it finally comes back out of the dealer) :mad:
07-02-2007, 08:00 AM | #5 |
22
Rep 528
The leak was just above the driver side window, toward the front of the window, coming from inside the seam.
It was a constant drip. The dealership confirmed the leak.
E92 335
07-02-2007, 10:30 AM | #6 |
148
Rep 1,060
After the rain we have had over the last couple of weeks in UK it has given the vert a good water test. No leaks at present but thanks for the information another thing to look out for on our verts.
07-02-2007, 11:25 AM | #7 |
Rep 35
I noticed a few drops on the driver window, next to the A pillar...It could have been from me hosing it too hard when I was washing it. I will keep an eye out..
12-20-2007, 01:02 PM | #8 |
Member
Rep 3
Drives side A pillar leak
Just took delivery of my '08 335 cab. Two car washes confirm that I too have this "A" pillar/ Window seam leak by the drivers door. I'll report back on what the dealer does about it.
12-20-2007, 01:43 PM | #9 |
69
Rep 2,385
my bf doesnt have a e93 but he has a slk convert. and has the same problem, the leak is only from the driver side.
E90 06 325. AW. BEIGE. CF WRAP. SMG KNOB. BLACKLINES. MTECH. HARTGE JAPAN REP LIP. ACS CF ROOF SPOILER. CSL TRUNK. KWV2. LE37.
12-21-2007, 10:57 AM | #10 |
Member
Rep 3
Driver Side water leak
Dealer response to my problem and I quote:
"The car is to be hand washed only, if you go through a car wash it will leak. In the owners manual it will give instruction on how to wash properly." And, thanks to this forum my complaint had more credibility so for round 2 they have agreed to investigate. More later. |
12-21-2007, 11:08 AM | #11 |
53
Rep 2,384
Drives: W211 E350 4M MkV GTI 987.2 S
I had my front seal replaced under warranty and it leaks exactly the same as before while in a touchless car wash - a few drops at the A-pillar on the passenger side and a little bit more on the driver's side. I guess this is just the way it is. The dealer gave me exactly the same warning about touchless car wash when I took delivery in the summer. They also warn me that the two parcel panels on the two sides of the trunk near the rear bumper will get wet too once in awhile and that's due to the way the roof drainage is designed.
07 E93 335i - Returned at lease end
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged. 09 MkV GTI w/Leather & 18" Huffs. F1 Asym 10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels |
12-21-2007, 12:20 PM | #12 |
936
Rep 4,326
Drives: M340
If you have time...... read this!
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
01-11-2008, 01:30 PM | #13 |
Member
Rep 3
A quick update from my recent dealer inspection of the drivers side A pillar leak. Their inspection came up with no findings... I immediately headed to the car wash and now find both sides have the same slow water drip afterward. At least now I have the start of a documentation trail.
More later as this adventure unfolds. |
01-11-2008, 01:41 PM | #14 |
45
Rep 795
I have never had a leak through torrential rains and washes. What this says to me is that when the roof is assembled properly, it works perfectly. I hope your dealer knows how to do it right and trust me it won't leak at all.
01-11-2008, 05:21 PM | #16 |
138
Rep 1,424
Drives: '23 i4 M50, '15 M3, '18 911
I haven't had any leaks in the top of my 'vert... yet.
But that statement may have just jinxed me. Good thing I live in a desert! |
01-11-2008, 06:32 PM | #17 |
152
Rep 3,983
01-11-2008, 07:05 PM | #18 | |
18
Rep 201
01-11-2008, 10:22 PM | #19 |
General
663
Rep 26,878
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
Wow. . . What a bummer. I'd be kinda pissed
01-11-2008, 10:33 PM | #20 |
46
Rep 502
+1...same here no leaks.
"WorldsQuickest 335i E93"
SMART-Top /One-Off Opaque Vinyl EYELIDS / 30% TINT / A.C.SCHNITZER Pedals / "M" Tri-Color Wheel w/Paddles / EIBACH Pro-Kit / AKEBONA F. & EBC RED-STUFF R.Dustless Pads / Drilled & Slotted ROTORS / MIRO M6 Reps / MICHELIN PS2's / U.R.Coated DP's / CYBA-QUAD Exhaust Tips / BMS-TUNED... |
01-12-2008, 09:35 AM | #21 |
45
Rep 795
Leaks or not, a hardtop will never give you open sky at night, the warm breeze enveloping you as you listen to the sonorous music of 6,000 RPM.
Although, I wouldn't mind a cloth top option. But then you can't shut the top and have an extremely quiet hard top experience ever.
01-12-2008, 12:45 PM | #22 | |
241
Rep 1,906
