2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums ASIA For those here who have 528i (both N52 & N20)
      05-24-2012, 11:50 PM   #1
clarence
54
Drives: F30 328i M-Sport
Do u know the exact size of the standard front discs brakes? Anybody care to use a tape measure to measure?
      05-26-2012, 11:32 AM   #2
AC_S5
AC_S5's Avatar
Drives: 2011 F10 523i
I do believe a detail spec sheet can be found on the internet without using a measuring tape to measure. Plus a measuring tape wouldn't be as accurate as those figure on the spec sheet I think.
2011 F10 - Sophisto Grey / Cinnamon Brown
You can find me in E60.net too!
Gone (but not forgotten)
2005 E60 523i, 1999 E39 523i, 1998 E46 323i
      05-26-2012, 01:36 PM   #3
clarence
54
Just found out, BMWHK is being stingy & HK-spec cars have smaller front discs than EU-spec. 330mm front & rear.
      05-27-2012, 04:50 AM   #4
AC_S5
AC_S5's Avatar
Our car should be EU spec as well. Bear in mind the year when you check those spec. An earlier model 528 with the I6 engine should have a bigger disc because of the heavier engine.
      05-27-2012, 03:24 PM   #5
clarence
54
Car is EU spec, but check ur build sheet, it may have option code S212A, which is "Country Specific Brake System". This means US-spec brakes & calipers.
There's no difference in the brakes between N52/3 & N20, & S212A potentially exist in all HK-spec cars except M5.
In a nutshell, if no option code S212A then front brakes 348mm. If it has S212A then 330mm front discs & different calipers (basically same system as 523i/520i).
      05-27-2012, 08:41 PM   #6
AC_S5
AC_S5's Avatar
Good in depth research there... think positive, if you ever want to ditch your brakes for something else, you wouldn't be as reluctant
      05-27-2012, 09:14 PM   #7
clarence
54
I haven't ordered the car yet, still at initial research stage.
      05-27-2012, 10:32 PM   #8
mlai
mlai's Avatar
Hong Kong
168
Drives: 650GC/E93M3/Lexus LS600HL
I will be parting with my "fake" brembos front coming fall..... Will probably look slightly better than the stock 330mm brake kit if any of you are interested
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      05-27-2012, 11:14 PM   #9
AC_S5
AC_S5's Avatar
I thought you will be putting them on your GC or you are going to buy a new set for the new car
      05-27-2012, 11:29 PM   #10
mlai
mlai's Avatar
Hong Kong
168
May just stay low and test out the stock brakes first
      05-28-2012, 02:16 AM   #11
clarence
54
Will be, but it'll mean big rims. I'm currently looking at Brembos with 365mm discs (want to stay on 18" rims), how much in HK?
      05-28-2012, 08:38 PM   #12
AC_S5
AC_S5's Avatar
Ask mlai to sell you rim and brake package... 18" is too small for this car.
      05-29-2012, 01:48 AM   #13
fckb
fckb's Avatar
Hong Kong
Drives: E39, E87, E60, F10, G30 Alpine
i wouldn't mind picking up 2nd hand wheels
5post
