05-16-2012, 08:15 PM | #1 |
472
Rep 1,659
Drives: 2022 WRX World Rally Blue
Air Filter Replacement
Has anyone been brave enough to figure out how to change the air filter? I just ordered a K&N filter for my car and was wondering how difficult it is. Thanks in advance!!
05-26-2012, 09:16 AM | #2 |
472
Rep 1,659
Done
I found out how to do it. I gave a call to Robert at K&N. I sent him a picture of the engine bay. First, unsnap the four silver clips on the left. Then you have to loosen up the intake tube from the mass air flow sensor. Give a gentle tug on the rubber mounts and you're in business. The mounts are pliable enough you can pinch them together and make the process a little easier.
AhzeeF3226.50 |
05-26-2012, 04:50 PM | #3 |
210
Rep 3,288
Drives: anything given a chance
A drop in filter should be easy to do, are you trying to explain removing the air-box and fitting a cone setup?
05-26-2012, 05:30 PM | #4 |
472
Rep 1,659
drop in
No, Just the drop in filter. For some it's easy and obvious. For people like me, not so much.....
06-01-2012, 12:52 PM | #5 |
Rep 141
Drives: Black F30 N20
06-01-2012, 06:15 PM | #6 |
472
Rep 1,659
I replaced the filter for hopefully a little better performance and mileage. I have them in everything from my work car to my motorcycle. It may just be my imagination, but I have used them for about fifteen years easy. They have a million mile guarantee and can go about 50,000 miles without cleaning. Plus, under the Magnuson Moss Warranty Act, it won't screw up your warranty.
06-21-2012, 06:20 AM | #7 |
210
Rep 3,288
I was doing some searching on this a few days ago, as I'd like to put a K&N or BMC filter in my car when it arrives.
I believe the flat-panel replacement for the E9x will fit in the F30. |
08-28-2012, 12:37 AM | #9 |
14
Rep 75
afe makes replacement filters for the f30. there's the option of a wet and dry filter material.. haven't done this mod yet, but will soon. stock air filters always hinder a little performance (and overall sound imo)
the only thing in this world that gives orders is balls. You got that? Balls. |
09-18-2012, 02:32 PM | #10 |
Sarcasm free with all posts.
Rep 441
09-29-2012, 09:38 PM | #12 |
42
Rep 537
Drives: 2013 335i M
There cant be much diff in performance with a drop in filter..can there?
M5 with lots of goodies
01-02-2013, 11:37 PM | #13 |
21
Rep 244
Install Guide
Gentlemen and Ladies,
This guide is intended to help anyone install their new K&N, aFe, etc. replacement air filters. This is also intended for the 335 with a standard air box, or, NOT replaced with a CAI. Reasons for getting a high-flow filter: 1. Our cars have a TURBO. This means that they'll run a bit hot over their NA cousins, along with needing more air for more proper combustion with the forced induction. I say let's give it to them!! 2. As others have said, it won't void your warranty, will give you (slightly) more hp, (slightly) better gas milege, and doesn't have to ever get replaced. So it pays for itself after 2-3 replacement filters. I've had a K&N in my Corvette, Mazda3, Altima SE-R and previous 328Ci, and have experienced noticeable gains in hp, torque, and fuel economy after their installation. 3. It's so easy (yes, if a caveman drove an F30, he could do it to!) Steps: 1. Pop the hood 2. Locate the 4 silver tabs holding the top of the air cleaner box in place. If you are facing the vehicle looking into the engine bay, there will be two on the right side, one on the top left, and one on the left side. 3. Pry them loose using finger pressure. Be careful that they stay in place. I almost lost one into the depths of the engine bay!! 4. Gently lift up the top of the air cleaner box and remove the stock filter. I found that I had plenty of room to remove the old filter without disconnecting anything. 5. Place your replacement filter, drop the lid on top of it (it guides itself back into place with its tabs), lock it back in place with the tabs, and you're finished! 6. Place the accompanying sticker somewhere conspicuous on the car. You'll get 10 hp from that mod alone!! Enjoy, and happy motoring!
Individual Order 2013 335i M-Sport through BMW Military Sales / Mineral Grey / Coral Red / 4MR / ZMM / ZPP / ZTP / ZDH / 2TB / 494 / 688 / ///M Performance / ///M5 Blue Brakes / K&N / aFe / H&R / Turner Motorsports / SportLine Wheels / Details, details, details...
TarekS9929.50 |
01-02-2013, 11:41 PM | #14 |
21
Rep 244
As an addendum to the previous install guide, here is the part number for the K&N filter: 33-2997. I used the configurator tool on K&N's website and had it shipped directly from them. The filter fit perfectly. Hope this helps!
01-21-2013, 06:01 PM | #16 |
649
Rep 4,323
I'll do it after the 50k service is up...why pay to replace a filter they'll replace for free?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
sgovind77.50 |
02-18-2013, 11:15 PM | #17 |
Delivered!
13
Rep 139
Note, The K&N 33-2997 Filter is available on amazon for ~$37, versus the ~$55 on the K&N website.
Amazon link below, for those interested. http://www.amazon.com/33-2997-Replac...=K%26N+33-2997
Delivered!: 2013 F30 335i M Sport, 8-speed Sport Trans, Estoril Blue/Coral Red, 403M, Premium Pkg, Dynamic Handling Pkg, Driver Assist Pkg, HK Sound, Enhanced BT & USB
03-19-2013, 04:23 AM | #19 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
I put the K&N filter in my 335 (Amazon $37) when I did my oil change. much higher quality over the stock Mahle paper filter. Very easy, straight forward remove and replace air filter.
05-27-2013, 03:50 AM | #20 | |
2472
Rep 4,653
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
E90X6.00 |
06-13-2013, 09:57 AM | #21 |
248
Rep 1,436
I have the afe dry filter, it's very good in my sandy weather and you have to put in consideration K&N is oiled so most oil is sucked up on your MAF and it will be clogged sooner that's for any oiled filter
06-29-2013, 02:56 PM | #22 |
Rep 25
Aftermarket filter on the N20/26 IMO is a waste of money.
BMS found no power gains over the stock air box setup. Maybe if sound is changed then sure... but I'm not spending money on something that has minimal gains and is covered under factory maintenance. |
Billfitz8243.00 |
