05-16-2012, 01:18 PM | #1 |
376
Rep 2,526
Light Painting Cars: B800 + Vagabond on a stick
Sorry if you were expecting photos...this is a work in progress.
I wanted to start light painting cars, so I made this: The Vagabond mini will attach to the bottom of the stick to balance out the weight. Question is, what type of softbox do I use now? Square, rectangular, octagonal? Size/dimensions? Anyone with experience in light painting cars, chime in, please! |
05-16-2012, 02:51 PM | #2 |
183
Rep 2,391
i used a small stripbox for these:
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust kw v2 | hotchkis front sway | vmr v710 |
05-16-2012, 11:24 PM | #4 |
183
Rep 2,391
it's an AB stripbox, like 36" by 9" or something like that.
05-19-2012, 04:44 PM | #5 |
376
Rep 2,526
AB800 started smoking at highest modeling lamp output using the Vagabond Mini to power it, so I switched it out for a normal 60W bulb. I'll post test shots in a bit...hoping to find someone's car to shoot with tonight.
I didn't use a softbox, by the way, just the dish reflector. EDIT: Going out to Home Depot to see what different bulbs and mounts I can get...softbox is totally unnecessary I think! Last edited by TWiTCHY; 05-19-2012 at 05:44 PM.. |
05-19-2012, 07:49 PM | #6 |
468
Rep 6,798
in that first pic, turning the wheel like that makes it look really distorted.
05-21-2012, 06:43 AM | #8 |
183
Rep 2,391
why are using the modeling lamp? use the strobe.
05-23-2012, 08:36 PM | #10 |
183
Rep 2,391
what are you using f/16 and 10 seconds?
with the strobing method, you can light what you want for each shot and composite later. that way you can focus on the back side of the car (relative to the point of view).
05-23-2012, 10:20 PM | #11 |
679
Rep 5,382
does this count as light painting? i did this with a SB-600, all in one shot. F8, 20 sec exposure. flashed once on front bumper, and twice down the sides.
05-23-2012, 10:24 PM | #12 |
679
Rep 5,382
this one is with a led work light. two images into one.
05-24-2012, 09:57 PM | #13 |
376
Rep 2,526
There's no right or wrong way of doing this...but there are better ways in achieving a certain effect.
I'm going for those white streaks of light - the highlights that run along the lines of the car. Photos like this, by Webb Bland: I am trying to emulate this effect using light painting, and it's very possible given the photos I've taken already. It's a matter of knowing where to run the light across and at what angle so that the light bounces into the camera. The height and angle of the light relative to the car's surface and camera position is everything. I'm going to practice that more on a car with more lines, rather than different camera/light settings. |
05-25-2012, 09:02 AM | #14 |
183
Rep 2,391
that one is an effect of the overhead lights and composited with selective strobing.
05-26-2012, 12:46 AM | #15 |
aka 1013MM
1253
Rep 9,545
no stick....
I can tell you that webbs was not light painted. in fact the car was not even shot there.
