Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Changing ALL the Fluids
      11-05-2005, 11:37 AM   #1
fredtoo
fredtoo's Avatar
15
Drives: 325 328 350
1986 328  [0.00]
2006 325  [0.00]
With 1500 miles on the car, I want to dump the Oil, Manual Trans Fluid and the Differential Fluid.
The dealer thinks that this can not be done, as the trans is "sealed".
I have a hard time beleiving that there is no drain plug on the manual transmission.
Is there an on line parts diagram that I can look at?
Where?
      11-05-2005, 11:40 AM   #2
Jesse Wilson
12
Drives: 2006 325I
I believe that it is "sealed" but it still can be done I think. They say it has "lifetime" fluid in it.
Jesse
      11-05-2005, 12:25 PM   #3
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
337
Drives: 2006 E90
Where?
There might not be a drain plug.....but you can remove the whole pan to change the fluid....cause that's how I changed my transmission fluid before....then resealed it with a new filter/gasket/silicon.
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      11-05-2005, 12:40 PM   #4
fredtoo
fredtoo's Avatar
15
Drives: 325 328 350
1986 328  [0.00]
2006 325  [0.00]
I have the manual transmission. There is no pan.
