e93 under dash heat !
05-04-2012, 05:07 PM | #1 |
886
Rep 2,720
Probably this is discussed before. I just noticed the under dash area is hot on both driver and passenger sides. Red-blue switch is set on blue(cold). AC, blower, everything is off. Even with the top down, the heat is still there.
It seems like engine heat, may be the insulation is not working properly. my car is 2007 328i 56k miles. I'll take the car to dealership next week, but just wanted to check if someone can throw some light on this issue. Thanks. |
05-04-2012, 05:37 PM | #2 |
Resident Car Audio Guru
Rep 597
I have the same year, but the 335. I have not noticed this. There may be a solenoid issue , or a switch problem. Does it still emanate heat with the AC on?
05-04-2012, 06:03 PM | #3 | |
886
Rep 2,720
Actually the heat is not coming from the vents. Its the whole under dash area hot. If you touch it you can feel the plastic is hot. |
05-04-2012, 06:09 PM | #4 |
Rep 597
you may have a leak from the heater core. If you can find the source of the heat you'll find the problem. Be careful digging around in the dash...it's tight, and the source of heat might be VERY hot.
05-04-2012, 06:58 PM | #5 |
886
Rep 2,720
thanks for the lead. my car is still in warranty, will let the dealer check it.
05-05-2012, 12:22 AM | #7 | |
BMW Noob
Rep 111
