Angel Ring Not Working
05-01-2012, 03:25 PM | #1 |
Rep 137
Hi folks, one of the angel lights on my 330d is not working but has anyone replaced the light ring or is it a bulb that you need to replace?
05-01-2012, 03:47 PM | #2 |
10
Rep 260
It'll be the bulb mate and it's a pita to do as you've gotta take the inner wheel arch out afaik or thats what i did anyway but takes about 15 minutes.
05-02-2012, 07:17 AM | #4 |
70
Rep 275
its the bulb mate, as I showed you on my car
H7 type bulb, takes about 2 minutes to change. Halfords charge about 15 quid each, or order some GP Thunders, or LED ones from the classified section to get rid of the horrible yellow
Previous: 2002 E46 330i M-Sport (m54b30 LCI), 2007 E92 335D M-Sport Coupe (m57), 2003 z4 3.0i (m54b30), 2010 E92 325D M-Sport Coupe (n57 LCI), 2019 F36 430i M-Sport Pro Gran Coupe, 2018 F36 440i M-Sport Pro Gran Coupe MPPSK
Current: MY2021 M550i, Aventurin Red, Ivory Nappa, Comfort Pack, Tech+ |
05-02-2012, 02:18 PM | #5 |
80
Rep 618
I have a similar issue to this, however mine hasn't stopped working completely, one side is very very dim (the rings not the light itself).
I have the led upgrade however am considering a change to GP thunders. As it is dim, could this be a loose connection or a bulb on its way out? And if I need to change the bulb, do I just need one bulb or one bulb per ring TIA and sorry to the op for jacking the thread.
M340d - Brooklyn Grey - Cognac
05-03-2012, 06:29 AM | #6 | |
148
Rep 1,060
05-03-2012, 07:38 AM | #7 |
1042
Rep 6,946
Mine went recently, just bought a standard bulb to keep both sides the same. Am pretty OCD about these things so went to BMW to make sure the light was exactly the same, £25.27 later and its all good again, apart from my wallet !!
05-03-2012, 09:34 AM | #8 | |
80
Rep 618
I'm not 100% sure as the upgrade was done by the previous owner, I think its the H8 upgrade. If I were to change I would obviously change both sides. As there are two rings on each side I wondered if each ring required a separate bulb.
05-03-2012, 04:43 PM | #9 |
Rep 137
One Ring Out
Ian, only one of the rings is out, the inner ring nearest to the grille not the main light.
So, you all reckon bit of a pain to get to? I need to see what time of bulb I need. Thanks for all the replies. Stuart |
