TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Xenon Conversion
      05-01-2012, 02:42 PM   #1
Danny.B.
Danny.B.'s Avatar
94
Drives: E90 330d M Sport
Xenon Conversion
Hi Guys
Probably should of changed the title because its been done to the death!
But got a slightly different question, aswell as the obvious.
The Pre LCi Xenon lights on a E90/91 how many different types are there?
2 or 3?
Xenon
Bi Xenon
Adaptive
Or are Xenon + Bi Xenon the same (i know what Bi Xenon is, but are ALL BMW E90 xenon units Bi Xenon?)
Also, what else is needed to convert from halogen? Complete lights, blubs, ballasts etc
Ive got headlight washers already so just need to get auto leveling retrofitted also, am i missing anything else?
Cheers
And as is the norm nowadays... A thank you for reading
      05-01-2012, 02:49 PM   #2
Delta0311
7478
Drives: 2011 BMW 335xi E92 2016 228xi
You will need a set of working OEM Xenon headlights
plus this
http://www.storenvy.com/products/259...ls-d1x-hid-kit
      05-01-2012, 02:51 PM   #3
garytc78
10
Drives: F31 330d M Sport
Nice pic danny ;-)
      05-01-2012, 05:47 PM   #4
IanS100
IanS100's Avatar
England
136
Drives: 520d F10 LCI M Sport
I've previously had a regular xenon conversion but often wondered what exactly is a "bi" xenon, does that mean main & dip are xenon? & is it one bulb or two?
Cheers
      05-01-2012, 06:30 PM   #5
parapaul
parapaul's Avatar
118
Drives: E91 330d M Sport
Bixenon is 1 bulb, the high/low beam is selected by a reflector inside the headlight unit.
Just how many Yorkshire sheep can you fit inside one exhaust?
      05-02-2012, 10:21 AM   #6
NickP
Detailing
NickP's Avatar
13
Drives: E90 330d
Originally Posted by garytc78 View Post
I've just done this and their are only 2 types both are bi xenon meaning that the headlight and flash are done by the same bulb,
the adaptive ones are a pita because you need to upgrade some thingymabob to make them work (they turn when you turn your wheel)
I bought some lights cheap that didn't have the standard ballast or bulbs so it has an aftermarket hid kit but instead of the rubbish
H7 bulbs you get i've some d2s bulbs witch is basically the same as the d1s bulbs you should have.
It is basically plug and play but to get the bi xenon to work you need to bridge a few wires in the connector block, I haven't done this yet but
I will let you know how this goes when I do it.
I have retro fitted OEM Xenons (Pre LCI) on mine, and they're not Bi Xenon....
      05-02-2012, 10:53 AM   #7
garytc78
10
They are bi-xenon you just have to wire it up so it works.
Their is a DIY retro fit guide on here.
      05-02-2012, 11:37 AM   #8
NickP
Detailing
NickP's Avatar
13
Drives: E90 330d
Off
On
High Beam (not great pic as on phone)
There is no shutter on the Xenon projector that I can see......
      05-02-2012, 12:24 PM   #9
jak_ir
Drives: BMW e90 330i
^ Thats the same on mine. Halogens are used for full beam
      05-02-2012, 12:46 PM   #10
Danny.B.
Danny.B.'s Avatar
94
so there are 3 different types then?
      05-03-2012, 03:04 AM   #11
garytc78
10
There is a shutter the inner light is not a main beam its a corner light that will only work if you have the correct module.
Have you seen how dim the inner light is?
      05-03-2012, 04:16 AM   #12
Danny.B.
Danny.B.'s Avatar
94
I did think it wasnt very bright!!
Anyone got a set of bixenons for sale
      05-03-2012, 04:29 AM   #13
garytc78
10
Did you fit these yourself?
      05-03-2012, 04:35 AM   #14
jak_ir
No I didn't fit them; they were already on the car when I bought it. I thought the cornering lights were for the LCI models?
      05-03-2012, 04:56 AM   #15
garytc78
10
The inner lights come on when your turning if they where on the car when it was built but if they where retrofitted they don't they come on as main beam because that's where it is on the halogen lights.
But if you connect the wiring up for the shutter the dipped beam moves and you get your bi xenon.
Here is the explanation.
http://www.e90post.com/forums/showthread.php?t=28035
