BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > 2008 335i Coupe suspension
      04-29-2012, 10:43 PM   #1
DCbmwGuy
Drives: 2008 BMW 335i Grey
I am thinking about getting 19" wheels for my coupe. Two question:
1. What type of springs would you recommend for 335i coupe?
2. How low would you recommend I drop the front and rear springs to make the 19" wheels look low profile but w/o degrading the suspension or performance?
Thanks in advance for all comments.
      04-29-2012, 10:49 PM   #2
CrazyNole21
Phizzle
CrazyNole21's Avatar
15
Drives: 07 BMW 335i
Most times when you change springs, you want to change shocks too to match certain desired rebound/damper. I have read some threads that certain spring/shock combo could be bad. Koni shocks and Eibach springs is a good combo but if you got the extra money, go the coilovers direction. KWv1 goes for like $1500 and the drop is perfect for your wheels, esp since you can adjust the ride height. I'm saving up for some coilovers myself.
      04-29-2012, 10:52 PM   #3
DCbmwGuy
Awesome. I'll look into the coilover. I'm not going to short myself so whatever is best is probably the route I'll take.
      04-30-2012, 03:46 AM   #4
K3VMO
Drives: E93 AW 335i
Don't go with springs alone as you will stress out the remaining components. Go with coilover set. Your mechanic should put them on in a standard setting... drive it for a few weeks to let the suspension settle to its ride height... then lower +/- stiffen according to taste.
KW's & Bilstein PSS both good... I'm personally using KW V3's.
Tags
335i, springs, suspension
