Argh! Advice needed with recent purchase
04-27-2012, 02:14 AM | #1 |
23
Rep 340
Bought a used e90 55 plate 325i from a trader last week. 34k on clock and full history confirmed by BMW. Idrive elec seats etc. Paid top whack as it was like new!
Since then the car has failed to start and needed to be jumped so I put it down to the battery never being replaced and changed it yesterday. All good for rest of day, but again left overnight and failed to start again this morning. Sounds like a battery drain somewhere which could be anything. Are there any common issues like this that are easy to fix? If not I will be pushing the trader to take the car back which would be easier said than done. Advice appreciated as this is souring my first experience of BMW ownership |
04-27-2012, 02:20 AM | #2 |
1867
Rep 13,043
Drives: BMW M340I G20
Assuming the new battery had a decent charge, then for something to drain it overnight, it must be something drawing a reasonable load. I'd start with the start side of things. Recharge the battery and disconnect the heavy power cable to the starter motor.
Still worth checking the boot lights are switching off though. |
04-27-2012, 02:29 AM | #3 |
23
Rep 340
I did a 12 mile round trip in it after fitting so should've got charged up if the new one was low. No warnings at all on dash.
Does the boot light switch off once closed or is there an override? Not sure how it can be checked with boot closed. Am I doing something silly with the start procedure? Stick key on, foot on brake and press start button? Cat is in park. I did the exact same process when jumping it and it would start which rules out a dodgy start button. |
04-27-2012, 02:47 AM | #4 |
1397
Rep 8,083
The starting procedure is correct but the current drain must be fairly significant. Boot lights isn't a bad shout but even then it shouldn't drain a healthy battery overnight. Easy check though - take the bulb out.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
04-27-2012, 03:01 AM | #5 |
LSD - No, you're not seeing things
72
Rep 3,302
I drive will ping you when the voltage is low - its very obvious.
Are you getting the low battery voltage alert? What I'm getting at - are you sure the battery has drained, or it it a starter motor issue? There is no issue I know of specific to these cars, but only a generic fault find. Easy test is to meter the current drain, any auto electrician can do this quickly and cheaply. Try a mobile service like the AA/RAC - you have cover? Tech- there are heaps of stuff that run on these cars without you being present. I would attempt the easy fix first, battery completely disconnected for an hour to eliminate possible software issue holding on the ECU power or something.
04-27-2012, 03:17 AM | #6 |
23
Rep 340
No alerts or pings
If it starts when jumped the ok after a run, this should rule out the starter motor? When on time came out, they checked the alternator and said it was fine. Also the little green indicator was fine on the old battery. |
04-27-2012, 03:21 AM | #8 |
1397
Rep 8,083
I'd be removing the boot bulbs first.
Ian
04-27-2012, 03:39 AM | #9 |
12
Rep 123
Get the AA out mate, they have a device that checks various things for power drain, really good tool.
P.S Take the battery back to wherever you got it, they'll replace it. Had an issue with my e30 325 where it drained the battery every 3 months or so - Europarts happily replaced each time 'sorry sir, seems to be a faulty battery'! I had 4 batterys in total. |
04-27-2012, 03:45 AM | #10 |
23
Rep 340
04-27-2012, 04:39 AM | #11 |
23
Rep 340
If the lights aere left on the 'auto' switch, could this be a cause of the drain? no lights appear to be externally on when leaving the car, so a long shot. That is the only thing i can think of without yet trying any of the above suggestions.
Also, just rang the trader, he said they had no issues with the car while it was with them on their forecourt as they were moving it inside daily to ensure no oen nikced the wheels. They are happy to look at it, but strongly implied i must be leaving something on I can't think of anything i've changed? radio, lights etc all go off when switching off the car..... |
04-27-2012, 04:41 AM | #12 |
258
Rep 3,815
Just a side note I recall reading somewhere when changing the battery the e9x had to be coded to tell it there is a new battery.
F30 335i M Sport - now departed
04-27-2012, 06:12 AM | #14 | |
72
Rep 3,302
Only applicable if you have fitted a different capacity really. The DME uses the figures to accurately calculate battery run time and the warnings I mentioned. And the charge rates etc. If I leave the ignition and lights on in mine for a half hour then I generally get the low battery alarm. You are not. Which makes me wonder if the battery really is flat. Or perhaps the starter is drawing excess current/failing. You did fit EXACTLY the right size and cranking amp rated battery ???
04-27-2012, 06:59 AM | #17 | |
72
Rep 3,302
Perhaps its very remote, or there is no alternate transport.
04-27-2012, 07:04 AM | #18 | |
13
Rep 346
Post #11 says he did. He needs to give the dealer a chance to fix before he can reject the car. An auto electrican will be able to pin point the drain quite easy. Had an mr2 hat used to drain the battery over night and that was the boot light. |
04-27-2012, 07:58 AM | #19 |
23
Rep 340
It's not from a main dealer but the company I bought from has been told.
The new bosche battery is slightly better spec than the oem one. 74ah vs 70ah and higher cranking charge |
04-27-2012, 12:34 PM | #20 |
72
Rep 3,302
So you need it coding to the car.
05-01-2012, 07:44 AM | #22 |
23
Rep 340
trader has fixed the car and awaiting collection. turns out the 'battery amplifier' was faulty and draining the battery within 3hrs. Part replaced and issue resolved.
A common issued according to him... i didn't find anything on this forum, nor heard of a 'battery amplifier' before. Thoughts? |
