Help My car has been over heating 07 328xi
04-25-2012, 01:01 PM | #1 |
Rep 52
the shop thought it would be the thermostat so they changed it and its still having the same problem....ill drive about 60 and the yellow thermostat comes come...ill pull over and it'll turn red..my fan also goes into overdrive mode and gets real loud. i drive an 07 328xi and ive neer had a problem with it in the 120k miles ive put on it...please help
04-25-2012, 04:39 PM | #4 |
Rep 52
ive driven the car about 100 miles with this overheating problem but i stop the car to let it cool down...im going to get the waer pump changed...is all this driving going to be a permanent problem?
04-25-2012, 04:41 PM | #5 |
28
Rep 317
If you stopped and let it cool down when you got the warning, most probably nothing permanent happened.
BMW 320 dA LCI, BMW PPK - 197HP, 2010, sapphire black, steptronic
04-25-2012, 05:02 PM | #6 |
1911
Rep 13,104
It could be the radiator or the fan to.
Try to find the root cause if you can. Have you been doing radiator fluid changes and flushes on a timely basis. I think Mike Miller recommended a total cooling system rebuild at around 100k. |
04-25-2012, 09:39 PM | #7 |
20
Rep 120
OP, did the car go into limp mode when the light came on? You should not drive it any further until you get the water pump replaced. Have it towed to whatever shop you do business with.
And I have to ask: how did you put 120k miles on a 2007 vehicle? That's a lot of driving. |
04-26-2012, 08:35 PM | #8 |
Drivin' like I stole it. Cuz I did.
Rep 14
If they replaced the thermostat, lost some fluid and didn't bleed it properly upon refilling there could be air trapped in the system. It needs to be bled. But water pump would also be a more likely scenario at that mileage. Clearly you have done a ton of highway miles which means higher rpm for longer durations which naturally will wear the pump out.
E92 2007 328xi Auto. Sport, Premium & Cold Weather Pkgs. Stock but I keep it clean tho...
05-02-2012, 11:46 PM | #9 | |
Rep 52
05-02-2012, 11:48 PM | #10 |
346
Rep 2,396
05-02-2012, 11:53 PM | #11 |
Rep 52
