understeering?
04-22-2012, 01:20 PM | #1 |
84
Rep 703
understeering?
hello. i have a 335xi and i dont know how to solve this issue. i dont know if this is considered understeer or not. i know understeer would be like going 40mph and going around a sharp bend and the car just goes straight because the tail wont slide out. but what about when your not trying to powerslide or anything and the car just feels like its not very planted around bends on the highway? if i take a slight turn on the parkway the car feels like its wants to go straight instead of turn is that understeer even if i'm not trying to get the back to swing out? i have a staggered setup would this be fixed if i get a square setup? or is this not understeer and instead i should just get like a sway bar and m3 subframe bushings? i already have coilovers so that wouldnt be a solution. thanks guys.
04-22-2012, 01:28 PM | #2 |
597
Rep 3,386
i have the exact same issue in my XI. people say a square setup helps reduce understeer but i dont know if that is only when you are trying to get the rear to slide out. at highway speed i'm obviously not trying to get the rear to swing out but around bends it feels like the car rather go straight. i dont know if a square setup would help that or not.
04-22-2012, 03:35 PM | #4 |
597
Rep 3,386
04-22-2012, 03:54 PM | #5 | |
AC
95
Rep 2,387
use the cheapest solution first to see if it helps:
increase your front tires' pressure. Quote:
Your Supreme Leader
04-22-2012, 06:38 PM | #7 |
AC
95
Rep 2,387
you can try softening the springs on the front suspensions, lessen the stiffness of the front sway-bars, or increase the negative cambers on the front tires, but the most effective way (probably the more expensive option) is to increase the width of both front tires or use "softer" front tires than the rear tires.
Your Supreme Leader
04-23-2012, 08:00 AM | #8 |
Hellafunctional
37
Rep 426
achien: Just stop. You're spreading around alot of wrong information without knowing more.
OP: Oversteer is defined as the car's drive angle being less than the car's steering angle. If you were actually experiencing understeer on the highway, then you REALLY need to slow down. If you are within the speed limits than you are not likely experiencing understeer. Most likely you are experiencing alot of body roll. As the car turns, and inertia wants the body to continue straight, a loose suspension can be felt as "leaving you behind" after you turn. Nobody here can give you advice without knowing more about your car. Coilovers, alignment, sway bars, wheel/tire size, tire pressures, etc...
Go: Cobb S2+, Big Tom FMIC, CP-E DP & DCI, Royal Muffler, AR OC Turn: TC Kline/Swift SA, Vorshlag Plates, UUC Front Bar, H&R M3 Rear Bar, VAC endlinks & spacers, Forgeline 18x9.5/NT05 265 Square Stop: Endless MX72, Stoptech Rotors/Lines, Motul RBF600 |
04-25-2012, 04:27 PM | #9 | |
631
Rep 1,649
OP - before spending any more money on parts I would suggest finding your local CCA chapter calendar of events and sign up for the next Car Control Clinic or Street Survival school. Only after learning a bit more about vehicle dynamics and what it is like to actually push your car can you make an informed decision on a true handling upgrade. |
04-26-2012, 09:40 AM | #10 | |
Chief Executive
304
Rep 2,889
Drives: 2008 335xi 6spd Coupe
With a square setup (or at least not dramatically staggered) and moderate tire pressure adjustment, you should be in pretty good shape on the xi. If you're looking to go even further, the next step is a stiffer rear sway bar. The goal shouldn't be a lot of oversteer any more than you should be seeking a lot of understeer. The goal should be a very neutral, predictable condition when the tires break loose. You should, of course, not be breaking loose your tires on public roads. |
04-26-2012, 10:01 AM | #11 | |
19
Rep 210
I just purchased nearly the same vechile as you options, year and everything (minus exterior color). Are you running the 235/265 setup on your 189's or are you running that on your 19's? I wanted to get rid of the RFT's and was wondering if I could run that size on the 189's (mostly concerned with rubbing). I'm using stock suspension and probably will be for a while until I decide on some coilovers but won't be slamming the car since CT roads blow. |
04-26-2012, 12:21 PM | #12 | ||
AC
95
Rep 2,387
"Understeer, a problem that mainly affects front-wheel drive cars, occurs when the driver turns the wheel but the car keeps going straight or does not turn as expected. This is usually caused by the driver trying to take the corner too fast, but there are ways of correcting it by simply adjusting the tire pressure."
Read more: How to Reduce Understeer | eHow.com http://www.ehow.com/how_7890016_redu...#ixzz1tAU0lhm3 http://www.ehow.com/how_7890016_redu...-pressure.html http://homepage.ntlworld.com/terry.c.../handling.html Quote:
Your Supreme Leader
04-26-2012, 01:50 PM | #13 | |
Hellafunctional
37
Rep 426
Tire pressure: The "ehow" contributor is dead wrong. Under/oversteer is all about the relationship between the car's weight transfer and how that effects grip front v. rear. Grip is determined by the tire's contact patch. Increasing PSI reduces contact patch. Think about the concept of "pounds per square inch". The idea is to maximize tread use accross the tire by adjusting tire pressure. If the OP is running 40psi hot, then increasing the tire pressure makes the situation worse. I have a thread here about optimal tire pressures. Suspension set-up: Making the assumption (dangerous) that the OP has coilovers that run a soft rate, why would you want to add body roll and thus exaggerate the weight transfer? The last thing a MacStrut front suspension needs is additional roll and weight transfer in the front. Adding negative camber is correct. Tires: Mixing tires is a direction that someone who can't identify understeer does not want to go. Squaring the tires corrects understeer for only one portion of a corner. Do you know what portion of the corner the OP experiences understeer? However, first and foremost the OP needs to learn to identify what understeer is, how/why/where it occurs, and how to correct the driver's inputs in order to correct it.
04-26-2012, 02:39 PM | #14 | |
AC
95
Rep 2,387
Try reducing your front tire pressure down to 20 lbs and see how loud it screams when you corner (and how much under-steer you will have).
A large contact patch will do nothing for you if your tire pressure doesn't hold up. if you need a large contact patch, use wider front tires instead, not decrease the tire pressure on the front tires. There is nothing we can do about the weight transfer of the vehicle (other than removing non-essential items like seats, carpets, radio, or air-conditioner) because the chassis is designed this way. OP is asking for opinions on the forum because he doesn't want to spend thousands of dollars asking for advice from a local tuning shop. If we just tell him to go to a local tuning shop for advice, he could have skipped this forum and save himself time. Quote:
Your Supreme Leader
04-26-2012, 03:21 PM | #15 | |
Hellafunctional
37
Rep 426
There is absolutely something we can do about weight transfer: we can slow/shorten it or decrease it. Slow it through increased spring rates and sway bar rates. You can decrease it by widening track, or decreasing the lever between the roll center and center of gravity. Or, the OP can learn that slow in fast out is the best way around a turn and decrease the weight transfer that way. Also, increasing the amount of roll up front, increases the distance that the weight is transfered. This is multiplied by the lever arm between the CoG and roll center, and then dramatically deteriorates the front suspension geometery. This increases understeer with MacStrut front suspensions. I didn't send him to a tuning shop. I advised him to go learn how to control his car. BMWCCA, SCCA, street survival, local tracks, etc. My last track day cost $180. That will do more good than either asking random people that have never seen/driven his car what to do. I also just realized that this thread is like a primer on logical fallacies: red herring, false authority, non-sequitor, straw man, hasty generalization, affirming the consequent, etc... Take note, this is not how you should establish an argument!
Go: Cobb S2+, Big Tom FMIC, CP-E DP & DCI, Royal Muffler, AR OC Turn: TC Kline/Swift SA, Vorshlag Plates, UUC Front Bar, H&R M3 Rear Bar, VAC endlinks & spacers, Forgeline 18x9.5/NT05 265 Square Stop: Endless MX72, Stoptech Rotors/Lines, Motul RBF600 Last edited by Doyle; 04-26-2012 at 04:15 PM.. |
04-27-2012, 08:51 AM | #16 |
Caught the Bimmer-Bug
50
Rep 639
Take some performance driving courses. It will teach you how to drive and take turns properly.
After that's said and done, and you still have an understeer problem, I'd look into the car. |
04-27-2012, 09:45 AM | #17 | |
Chief Executive
304
Rep 2,889
04-27-2012, 09:48 AM | #18 |
Chief Executive
304
Rep 2,889
achien, no offense, but I think you should stop advising people on this matter.
