Headlight problem-turn signal won't turn off
04-20-2012, 08:50 PM | #1 |
Rep 18
Hi all,
I'm a bit new to this forum and was wondering if somebody here could help me out with a problem I just started having tonight with my 2008 BMW 328i Sedan. My driver side headlight turn signal won't turn off, even when the car is turned off and key is out. I have even tried setting the light switch to off. Also, when I set the turn signal switch to turn left it won't blink (but the rear light does as well as the side). I recently upgraded my factory halogen headlights to Depo Xenon HIDs and thought it might be problem with the headlight so I tried plugging in the original and the problem persists even in the original headlight. So that tells me that something else is wrong. Maybe a defective light switch? Any ideas? Thanks for taking the time to read this and any help/suggestions!! |
04-20-2012, 09:10 PM | #2 |
22
Rep 54
that sounds pretty wierd..how u manage to turn it off,unplugging the battery?
e93
04-20-2012, 09:26 PM | #3 |
Rep 18
04-21-2012, 01:11 AM | #5 |
21
Rep 240
Maybe its the parking light feature? On mine the Angel eyes stay lit, but it seems pretty similar.
Read the section of the manual on that, might just have to tap the lever up
13 F30 335i M-Sport EB-II/Black
Prev: 07 E92 335i Montego/Saddle - Stage 2+ |
04-21-2012, 01:13 AM | #6 |
The Logistician
69
Rep 799
Drives: 2022 230i M-Sport
Yeah that is what it sounds like to me. It is a warning when you are parked on narrow streets so you don't get side swiped.
04-21-2012, 01:44 AM | #7 | ||
Rep 18
No, I just went I tried that feature. It actually turns on the angel eyes for whichever headlight I choose and then gives the warning for the parking light when I open the door so def not that. However, I did get a new error symbol pop up when I just started my car, I've attached a picture for reference. |
04-21-2012, 06:21 PM | #8 |
Rep 66
Had something like this happen once on a e60 it was the turning signal arm stuck in the down position pushed it up and the problem fixed but it sounds like u have a bigger problem
04-30-2012, 08:41 PM | #9 |
Rep 18
yeah i ended up taking it in to BMW. at first they couldn't figure it out but they ended up saying the light control module was fried and had to be replaced and the whole car reprogrammed. got that done and everything seems to be working now.
05-14-2013, 01:23 PM | #10 |
62
Rep 99
Drives: 2018 Speed Yellow F80 M3
Garage List 2018 F80 M3 [10.00]
RIP 2010 BMW e92 335i [0.00] RIP 2008 E90 328i [0.00] RIP 1995 BMW e36 M3 [8.75] 2012 E93 335is [0.00] |
This happened to my car too. If possible could you give me a part number for the light control module.
