Car not tracking straight even after alignment: Coilovers to blame?
04-20-2012, 05:32 PM | #1 |
231
Rep 1,473
Took my car to a very very reputable suspension shop in the area to have the M3 control arms installed, neg camber added in through the camber plates, and aligned afterwards.
After all of that was done I noticed that the car would track to the right at highway speeds even on the most level roads. It is not terribly noticeable at lower speeds, and I don't remember it doing this before the install and alignment. The car has never been in an accident. Tires have about 2k miles on them and per shop are not the cause of the problem. I had the shop recheck everything and they said the alignment was perfect, and that the coilovers are likely to blame. From what I remember the driver side is about 1/2" higher than the passenger side. I am not sure if that was 100% due to strut length or spring level (JIC coilovers have both adjustments) but I believe it was a combo of the two. They tried to explain why this would cause the car to track to the right but it was a bit over my head but had something to do with sway bar. The car also has an interesting tendency to torque the wheel clockwise when hitting bumps at highway speeds when the initial deflection of the car is upwards. Anyone care to explain what is going on and how I might go about solving this on my own before shelling out another several hundred to get it corrected. I assume height adjustment is the first thing. Is that it though? |
04-21-2012, 08:52 AM | #3 | |
146
Rep 1,160
Hmmmmmm....did the alignment shop place weights in the car per BMW's recommendation before performing the job? Hunter reputed to make the BMW Kinematic Diagnosis System (KDS) used for dealer alignment. Register to download this informative BMW doc at bottom of first post; goto page 34 for preload (weights) spec. That site's a treasure trove o'info. Also: |
04-21-2012, 04:31 PM | #4 |
231
Rep 1,473
Alignment was done the old fashion way. I was not sitting in the car. No weight was added.
In the past the car was aligned on one of the Hunter machines. Again I have never sat in the car nor was there ballast. Never had an issue with the computer alignment. |
04-21-2012, 06:40 PM | #5 | |
146
Rep 1,160
Assuming control arms were new and genuine BMW M parts, replacing old M control arms, look at the install - ask what torque values were used. You might want to jack it up, take a wheel or two off, and inspect.... Front control arms only? Guessing you have the other M parts on the front end. If not, M tension struts and front sway, please, provided your coilovers are compatible. Easy DIY if you have a place to work. |
04-21-2012, 09:36 PM | #6 | |
231
Rep 1,473
I can't say that the problem wasn't there before the control arm install and alignment, I can say that I did not notice a problem before they were done. |
04-22-2012, 12:44 AM | #7 |
146
Rep 1,160
Shoulda asked. Poss wear on coilovers / many miles? Can see a diff between sides would cause the problem.
04-22-2012, 12:53 AM | #8 |
126
Rep 654
I have the same problem, posted here several times, no luck.
There's a post here somewhere on how to re-align your front sway bar, which could be the culprit. Give that a try. Me driver's side is taller about .6" inches, make the car pull to the right excessively. |
04-22-2012, 12:56 AM | #9 | |
231
Rep 1,473
The coilivers have both preload and strut length adjustments. Shop wants some time to adjust it all, but the labor charges are I know these guys know what they are doing. Just don't get how new m3 control arms + neg camber + alignment leads to a car that pulls. |
04-22-2012, 10:23 AM | #10 |
146
Rep 1,160
If I've read you right, relatively new sway. If adjustable end links, was all installed w/wheels at normal ride height, no load on the bar [torque due to one side or both a bit off]; checked after new suspension parts?
04-22-2012, 11:58 AM | #11 |
34
Rep 715
Im on my way to install new coilovers , but I am not sure if I should go with Eibach R1 or the JIC CROSS. I got a lot of potholes and bad road sections in my town so I would go for the one that handles bad road the best.
Stangorang, you have any experience so far with bad road and these coilovers ? |
04-22-2012, 12:41 PM | #12 |
231
Rep 1,473
No new sway. Stock sway still being used.
04-22-2012, 01:10 PM | #13 |
NeedsMoarBoost
42
Rep 527
odd, I just had BMW to my alignment for that reason... good luck...
08 135i 6m - 12.1@120.2 2.0 60ft - JB4/Meth - SOLD
09 335i e92 Mtech - RB FBO |
04-22-2012, 01:39 PM | #14 |
14
Rep 124
I am no expert but just throwing out an idea here. I see in the DIY instructions that one is supposed to compress the strut to bring the hub to approximate normal ride height prior to tightening the mounting points of the control arms. Is it possible the shop did not do this and could it somehow be related?
04-22-2012, 01:42 PM | #15 | |
231
Rep 1,473
04-22-2012, 03:33 PM | #16 |
231
Rep 1,473
Well I made some progress.
I measured the suspension with a digital caliper (spring perch to top of strut body, strut body length) and from what I can tell there were only 1mm differences here and there. I then swapped the left and right front wheels, unbolted the sway bar and bolted it back up and torqued to specs. The sway bar did not seem like it had much tension as I unbolted it. My inexperienced eye did not see any abnormalities on the tires. Took it on the freeway and the pulling is improved. Not perfect, but more livable. We shall see how long this lasts. Since I did both things at the same time I am not sure which one is responsible for the improvement. |
04-22-2012, 08:48 PM | #17 | |
146
Rep 1,160
