Warranty items that need doing - noob questions!
04-20-2012, 06:49 AM | #1 |
Rep 313
I've never had a warranty on a car before so am a little unsure on what the process is exactly for getting things sorted at the dealer...
Do I - 1 - Take it into the dealership and say I want these problems fixing under warranty 2 - Take it into the dealership and say I have these problems - they investigate then fix it/charge me for the time if they can't replicate/agree ...and with either of the above can I leave them a list of 2/3 things that need sorting or do they need to be booked/paid/fixed seperately? Apologies for the daft questions |
04-20-2012, 07:23 AM | #2 |
112
Rep 4,021
What problems do you have?
Is the warranty manufacturers or extended warranty? The garage will carry out their own investigation to see what the fault is. Phone up and make an appointment firstly. |
04-20-2012, 07:49 AM | #3 |
12
Rep 693
Phone the dealer your looking to book with and explain to them the problems. Tell them you have a warranty and they should be able to confirm if it will be covered, although sometimes they need to investigate further.
04-20-2012, 08:26 AM | #4 |
18
Rep 617
It depends if this is a new car warranty or extended warranty.
New car warranty. Call the dealer you bought it from and book it in. They fix it for free and give you your car back. Sometimes they may try to argue the toss over whether it's a warranty item or wear and tear but for a car still under the 3 year original warranty, this should be an easy argument for you to win unless you've really abused your car and they can prove the failure was caused by your abuse. Extended Warranty Call your dealer and book it in. They will attempt to diagnose the fault which you will usually end up paying for. They will then fix it under warranty or tell you it's not covered and ask if you want to pay to fix it. Sometimes you are lucky and they will just fix it and sometimes you'll have to try to argue your case. The extended warranty isn't underwritten by BMW themselves but another company so it's usually a little harder to get stuff sorted for free under the extended warranty. Either way you usually end up paying for at least the initial diagnosis part out of your own pocket which could be several hundred quid. |
04-20-2012, 08:48 AM | #6 | |
112
Rep 4,021
Loads of people have had work carried out without shelling.out.several hundred pounds. Most people speak highly of the extended warranty and wouldn't if it was costing.hundreds of pounds every claim. |
04-20-2012, 09:31 AM | #7 |
21
Rep 591
To the OP, great post, I wasn't sure what I would have to do if I ever get in this situation.
I hope the extended warranty is as good as people say it is. I have it on my car and I've happily not had to use it *touch wood* It's a piece of mind thing... |
04-20-2012, 09:50 AM | #8 | |
Rep 313
I should have said it is >3yrs old with an AUC warranty which is (I gather) the main dealer extended as opposed to the one you buy after a lapse? Not that I'm sure it makes too much difference Problems I want looking at are only little things but annoying nonetheless - Rear bulb holder reporting light failure but all lights fine - found a TSB to say it's a known issue and should be replaced - Seat belt assist things only picking up belt 50% of time at best as belt appears worn at edges where it has been picked previously - One exhaust looks like it sits about a cm lower than the other (maybe just needs bracket (?) tightening? It's due an MOT in July so I'm hoping if I mention the belt thing it may prompt them to fix that, the brake lights still work so it will pass in that respect. I think as it is less than 12months into AUC I also have MOT cover which covers a few things (like bulbs coincidentally) that aren't normally covered under the warranty itself Thanks for all your answers too btw |
04-20-2012, 11:30 AM | #9 | |
18
Rep 617
I guess I'll soon find out how good (or not) they are as I have booked mine in for them to look at a very annoying rattle which has developed in the cab roof and is driving me insane! |
04-20-2012, 01:10 PM | #11 |
19
Rep 344
Drives: 911 C2S & '118D
From my experience;
Defiantly call before hand and book all items in to be looked at. Normally they will ask for the car for the day and either offer one of their loan cars or source a car from a rental company at a nominal fee, if it that what you require. In terms of internal rattles and squeaks generally thats not covered unless its a new car. But mechanical rattles and squeaks they should look at FOC. Originally had the 335i booked in with 1 BMW Franchise who said there is possibly a diagnosis fee of £60 But booked in at another franchise for next week for 4 items, under the AUC warranty with no mention of a diagnosis fee; Squeaky Passenger seat Metallic rattle (sounds like wastegates to me) Front tyres loosing about 8psi every 2 weeks, possible cracks Orange Battery light comes on periodically, about 2-3 times a week I also booked it in for an oil and filter change even though its not due for 3800miles. Labour only £72 as i'm supplying the oil. |
04-20-2012, 03:51 PM | #12 |
20
Rep 511
Recently dealt with my local dealer as the car suffering coolant leak, turns out to be a broken water pump, glad I opt for the extended warranty, and only paying the excess and all hassle free.
04-20-2012, 04:01 PM | #13 |
18
Rep 617
I'd usually agree but this is coming from the convertible roof so I am hoping it might be covered. Sounds like something has come loose although the roof still works fine. I can only give it a go and see what they say. Who knows they may surprise me and fix it for free in which case I'll be singing the praises of the extended warranty.
Either way what ever it is I'll need to have it fixed as it's driving me mental at the moment. |
04-20-2012, 04:03 PM | #14 |
spender of the kids inheritance
18
Rep 182
warranty
My experience of this was very positive with stockport BMW dealer. I bought a 2009 cara few weeks ago, it has warranty till july and came from a non bmw dealer. It was originally bought from Preston main agents so Stockport had no pevious interest in the car, but when I turned up at their parts department for a few little bits their storeman took me to see their service department because he checked the warranty date and said it should still qualify. Booked in fo a couple of days later...door seal,load cover, dashboard air vents(center and nearside one) all renewed no problem. Maybe they just want the future servicing to be done there but well pleased with them .Just walk in and ask I say...
