cc id 24 ...question
04-17-2012, 10:34 PM | #1 |
107
Rep 459
Hi everyone
yesterday after having a car wash went on 90 mile trip and on my way back i got some error codes ,abs icon in the middle and i believe a traction control light. No changes in braking at all.Parked turned car off ,and after 15 - 20 min car started normally same lights came back for short period of tine , and disappeared . I had following errors codes: 1. Start Assist (CC-ID 354) 2. Brake and Stability Systems Failure (CC-ID 236) 3. DBC Assist (CC-ID 24) I didn't take a picture but found one online (exact same problem) Does anyone knows what is this and how much would cost to fix it ? I don't have a warranty (07 328 (e90 ). Thanks in advance Last edited by 90rr; 04-20-2012 at 12:28 PM.. Reason: Update |
04-18-2012, 06:12 PM | #3 |
37
Rep 794
Drives: 2021 M2C, 97 M3
ABS issues are often caused by a failed wheel speed sensor. Good luck.
Performance Center Delivery, June 21, 2013: 2013 E92 335is | Le Mans Blue | Gray Leather with Black | 6MT | 19" Style 313's | Michelin Pilot Super Sports | BMW Carbon Fiber Rear Spoiler | |
04-20-2012, 11:50 AM | #4 |
107
Rep 459
A little update :
went to mechanic ... he cleaned all error codes (it was coming as failed hydro pump system,ABS and i believe a DCT system) . He said that could be something little as a ABS sensor or some other sensor (forgot which one exactly) or even wiring. As i mentioned warnings came again after for short period and disappeared .so far braking and handling are perfectly normal . When I do a "System check" it comes Clean. I am wondering if someone had a similar problem? Found some info online and says that it could be a very expensive repair (around $1700) hoping that is just some sensor ... Any inputs are welcome ! |
09-28-2012, 06:13 PM | #6 |
13
Rep 131
This just happened to me this morning.
All same codes. 2008 e90 M3. I have aftermarket brake setup . Lol warranty.... I'll update once I figure out what I'm going to do. |
10-09-2012, 04:32 AM | #7 | |
13
Rep 131
okay after a little over a week this code has disappeared and reappeared a few times. most recently it was off for the past 50 miles. then i opened it up at a red light with all traction systems on. My car broke a lot of wheel spin going into 2nd gear and the 3 same faults came on again a few seconds later. i will try to find someone to clear this with a scanner and see what happens as my car is not due for service until 04.2013 and the nearest bmw dealer is a $350 round trip boat charge. |
