320d de-flapped, breather changed, air filter changed
04-06-2012, 06:31 AM | #1 |
1115
Rep 2,072
I spent the evening/most of the night (finished after 2.00am) de-flapping my 320d and sticking in the blanking plugs, changing the breather filter, cleaning the EGR and changing the air filter.
This isn't a write up/how-to as there are loads of them already, just thought i'd share my experiences. It was a straightforward job but I it did twice on my 535d so that's like cheating. I will say that despite having 6 cylinders, the process was easier on the 5 as there were less others bits to take off (or so I remember it at least...). The fiddly bits like disconnecting the connectors under the mani without losing the little metal pins took me a while, the main job was very quick. Oddly, my breather filter was already a vortex type, I expected it to be a loo roll type as I checked the part number on top of the case last week and it was supposedly the part number for the loo roll type case so I went and bought a vortex breather. Once I took it off and realised I had a vortex already, I had to change the gaskets anyway so I just fitted the new one. I can see why the vortex is problem free - there is nothing in there to clog - just plastic. My air filter was black and my EGR and manifold were gunked up. I spent about an hour scraping out crap and cleaning them with brake cleaner (had no carb cleaner), changed the air filter (what a b*tch of a job that would be if I wasn't doing the swirl flaps etc) and put it all back together. I test drove it and it ran sweet - seemed to breath easier and pick up much better at lower revs. The main thing though is the piece of mind - I have read that the e90 doesn't have a swirl flap issue due to the design but its clearly BS - mine had 24mm flaps of the old style and one was quite bent which is what can lead to the screws working loose |
04-06-2012, 06:51 AM | #2 |
886
Rep 9,097
Good job....post some photos now.
04-06-2012, 09:17 AM | #4 | |
1115
Rep 2,072
My flaps are in the bin but I can pull one out and whip out my ruler! |
04-06-2012, 09:21 AM | #5 |
1115
Rep 2,072
04-06-2012, 09:48 AM | #6 |
156
Rep 2,475
I recall it was the spindle diameter that changed, as well as the way the flap was attached to the spindle. Not sure if 24mm is relevant, as the actual flap & inlet tract size is probably the same?
Did any e9x ever have the loo roll breather? I thought it was history before the end of E46 production?
340i F31
04-06-2012, 11:50 AM | #7 | |
1115
Rep 2,072
The larger 32mm ones (like my 535d had) have a thicker spindle and the flap itself is different, along with that jacket thingy around them. Still recall my flaps being attached by screws to the spindles. They are less liable to fail IIRC, but I don't know if they are 100% safe. On the breather you are probably right - the problem was when I got the part number off the top of the casing, I googled it and a forum result said that was the part number for the loo roll type casing, so I just went with it and bought a vortex. |
04-06-2012, 01:40 PM | #8 |
Rep 499
mobilejo - if the pin is 8mm which I think is the part you highlighted in orange then all is good.
04-06-2012, 02:07 PM | #9 | ||
1115
Rep 2,072
For me, the miniscule chance was enough to make me whip em out - I was going in there anyway to do the general de-gunking maintenance and the blanks are £24 so it just made sense. As you can tell, I just don't trust flaps, but I wouldn't want to tell anyone that their car is totally safe if there's even a tiny risk. |
04-06-2012, 03:15 PM | #10 |
337
Rep 1,660
AFAIK, all E9x have vortex breather filters.
Earlier E6x (pre LCi??) had loo roll type, which obviously caused problems. BMW then decreed that the breather filter should be changed every 3rd oil change (along with the air filter). The part number for the loo roll and vortex type are the same. Also, I understand that the E9x had the "later", larger spindles fitted. My late '04 E60 530d had the larger spindles, but earlier E6x had smaller ones - IIRC the shaft diameter was increased by 0.5mm. Mike |
