ZSP springs/shocks for e90
04-04-2012, 06:18 PM | #1 |
Rep 100
question about Sport ZSP shocks/springs. I have a pre-LCI e90 on non sport suspension. I came upon a set of ZSP shocks/springs but not sure if they're the right match for my car. (I've read that they will definitely fit, but I'd like to make sure that I'd be getting an even drop)
the springs are labeled D6 and D2... will these give me a good drop to sports suspension? Searching didn't give me a clear answer, only that it may not, but just wanted to confirm. If not, what do I need? Also... will the shocks from this set be usable in my car? For example, if I was to go with an eibach pro kit, or the right sports suspension that matched my car... would these shocks fit/work? appreciate any help, thanks. |
04-04-2012, 06:46 PM | #2 |
164
Rep 2,556
Since you've got an E90, I'd find out if those springs came off of an E90 and which motor/trans it has. Ideally, you want to get sport springs for the same car you have. OE sport springs and dampers will fit your car. Get the matching bumpstops and find out if the upper strut mount is the same between non-sport and sport.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
04-05-2012, 04:11 PM | #3 |
Rep 100
thanks, from some of the searching, i think these were from a 335 e90 so i'm leaning toward not installing them.
Any idea if the shocks are usable on a 328i e90 from a 335i? |
04-05-2012, 04:28 PM | #4 |
54
Rep 2,907
I think the stock/zsp suspension is interchangeable between the e90 and e92 so you should be fine. I sold my zsp suspension to a guy with an e90 (non-sport) and I don't think he had any problems.
If you want to use aftermarket springs, I would suggest that you upgrade your shocks and struts as well. |
04-05-2012, 05:10 PM | #5 | |
Rep 100
04-05-2012, 05:25 PM | #6 |
84
Rep 777
They def match, even if from a 335i to a 328i. You might get less lowering, but there will be lowering and as far as I know the differences are not too big.
One other thing to be aware: the shocks + springs are not the only things you would need to have the ZSP package, the sways bars I believe are also larger, but I can't recall if both of them.
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD . M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings . BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts . Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete |
04-05-2012, 06:40 PM | #7 | |
Rep 100
http://www.e90post.com/forums/showpo...73&postcount=3 |
04-05-2012, 06:49 PM | #8 |
Rep 5
i see you guys talking about dropping, i just bought a bmw 325i 06, and i want to drop like an inch or more, max of 2, and i have no idea on how to do it snd what to get, i was thinking about lowering springs but i dont wanna mess up my suspension. any ideas and suggestions, aprreciate it.
04-05-2012, 06:59 PM | #9 | |
Rep 100
