Audio - Basic questions
03-30-2012, 03:38 AM | #1 |
21
Rep 591
Morning chaps,
I'm completely new to BMW audio so I apologise for the basic questions. I've tinkered around with cars in the past, but never with the BMW. It's an e92 and I have the Pro iDrive (CCC - old version) with the basic speaker set up. My questions are: 1- Can I add the under seat subs to my current set up? Will these need coding, or can I just wire them up? 2- If I was to change the door speakers, are these a straight swap or will they require coding too? 3 - Would you recommend an amp if I was to upgrade, or would the standard system be good enough? There's plenty of information out there, but I'm a little confused with all the 'coding' requirements. So if someone could clear this up, it would be appreciated. Thanks, Steve Last edited by Ste133; 03-30-2012 at 04:34 AM.. Reason: . |
03-30-2012, 04:19 AM | #2 |
1868
Rep 13,043
Drives: BMW M340I G20
Coupe or saloon?
03-30-2012, 04:47 AM | #4 |
1868
Rep 13,043
I thought all Coupe's had subs under the front seats as standard.
03-30-2012, 04:54 AM | #5 |
21
Rep 591
03-30-2012, 05:00 AM | #7 |
21
Rep 591
03-30-2012, 05:28 AM | #8 | |
24
Rep 355
I am answering ur questions from what I know, and not what I have done (in due time).. 1. Your basic setup is waaay underpowered to add any aftermarket subs.. You will need an amp. (You should be having underseat 'woofers'. (they aint subs) ). 2. Door speakers are straight swaps. But watch out for mounting depths. you should be fine with anything under 42mm. 3. Go for a 4 or 6 channel amp. I went for the JL Audio xd600/6. Small amp which should fit in the OEM amp location (left side of trunk). You do not need coding if you are just swapping the speakers or adding an amp (since yours is a base stereo setup). However, when adding an amp, it is strongly recommended to recode your HU to Hifi, which will hive a flat cleaner signal to your aftermarket amp. To avoid coding and still achieve a flat signal you can also use a DSP like the MS8. Hope this helps. Please also correct me if I am wrong.. |
03-30-2012, 05:30 AM | #9 |
24
Rep 355
03-30-2012, 06:13 AM | #10 | |
21
Rep 591
03-30-2012, 07:59 AM | #11 |
Major Pain in the Arse
Rep 347
03-30-2012, 08:08 AM | #12 | |
24
Rep 355
http://www.1addicts.com/forums/showthread.php?t=505654 |
