What tyre pressure to run?
02-27-2012, 12:31 PM | #1 |
65
Rep 824
Drives: BMW 530e G30
Just got a set of Falken FK-452 all round 255/35 18 and 225/40 18 Load rating 94Y and the sticker inside the drivers door does not actually have the exact tyre size/load so not sure what to go with.
I've gone with 3 bar at back and 2.5 bar at front so far?
BMW 530e G30
02-27-2012, 01:13 PM | #3 |
469
Rep 1,539
I ran 32front/34back for a while and noticed inside edge wear and roll while cornering. I then switched to 36front/38rear following advice in another thread and it seems to be perfect now.
02-27-2012, 01:24 PM | #4 | |
141
Rep 736
255/35 18 = 2.4BAR/240kPa/34.8072PSI 225/40 18 = 2.2BAR/220kPa/31.9066PSI Not sure if these rates change between E90,91,93 and 94(?) But mines a Coupe. Hope this helps, Charlie Last edited by Squintstream; 02-27-2012 at 01:36 PM.. |
02-27-2012, 02:25 PM | #5 |
65
Rep 824
Thanks, the sticker on mine has the sizes but the load and speed rating is different so not sure how that makes a difference to the tyre pressure?
BMW 530e G30
02-28-2012, 03:13 AM | #6 |
16
Rep 280
Load and speed rating should not make any difference.
Like some others on here, I have switched from the lower pressures to the higher ones (the ones for more passengers etc) and prefer the handling. On all my other cars I have preferred the feel on the lower pressures (I do pretty much all my driving one-up). Maybe non-RFT and low pressures as well is just too much give in the sidewall for a car set up for concrete sidewalls. |
02-28-2012, 03:27 AM | #7 |
1545
Rep 8,972
Start with the part loaded pressures for the size and take it from there.
As said, don't worry about load rating, Y speed should be on there though as thats standard. |
02-28-2012, 07:17 AM | #8 |
65
Rep 824
So according to my sticker I should have 2.2 Bar at front and 3 bar at back?!
BMW 530e G30
02-28-2012, 07:24 AM | #9 | |
141
Rep 736
The 2.5 and 3.0 is only for running 4+ adults and luggage. But it would be worth monitoring the wear and try some of the pressures mentioned above if you experience inside edges running off etc. As said, load and speed ratings should not play into what pressure. |
02-28-2012, 08:11 AM | #10 | |
65
Rep 824
So in the column on the right where the following are: 225/35 R 19 225/40 R 18 255/30 R 19 255/35 R 18 and that column covers two rows in the next two columns... Do they both apply to all four sizes then depending on how many ppl in the car?
BMW 530e G30
02-28-2012, 08:23 AM | #11 | |
141
Rep 736
Column 1 = Tyre Size Column 2 = Front Pressure for tyres in Column 1 Column 3 = Rear Pressure for tyres in Column 1 Column 4 = Load (applies to all columns) Column 5 = Tyre Size Coulmn 6 = Front Pressure for tyres in Column 5 Column 7 = Rear Pressure for tyres in Column 5 Hope this helps. |
02-28-2012, 08:25 AM | #12 |
65
Rep 824
Yeh, sorry thats what I meant lol but couldnt explain as well
OK so I need to run at 2,2 and 2,4. (I get it now!) Thanks
BMW 530e G30
02-28-2012, 02:57 PM | #13 |
118
Rep 2,216
Drives: E91 330d M Sport
I can't remember the pressure in bar, but I run my E91 at 36F 39R. Seems to give even tyre wear and sensible ride comfort.
Just how many Yorkshire sheep can you fit inside one exhaust?
02-28-2012, 04:18 PM | #14 |
LSD - No, you're not seeing things
72
Rep 3,302
I run (and always have) my comapny car at the max listed pressures for the tyre size fitted.
I get lowest rolling resistance and greater economy. Ride is a little harsher, and stopping distance may be slighty adversly affected but hard to measure (I have tried however don't have the VBOX any more). But I still see NO unusual tyre wear as a result of what amounts to 'overinflation'. On the second set now, even wear and great economy from the little P7 Ecos' Steve
03-02-2012, 06:38 AM | #15 | |
has left the building
90
Rep 3,359
My plate (after conversion) comes in at 37F and 44R but I actually run at 38F and 45R. Horses for courses I suppose. |
03-03-2012, 04:54 AM | #16 |
24
Rep 1,872
I run 35f and 37R
E90 Msport, black leather, front seat heating,6Fl, bluetooth,sun protection glass,Alpine upgrade,non rft's
03-03-2012, 08:33 AM | #17 |
72
Rep 3,302
Been running the 235/35/19 Falken 452s at plated pressures.
Doing a lot of work this week to this car, but note the fronts are knocking off the edges slightly more than centre. I'm a motorway miler generally and this wear pattern suggests underinflation. I will now try upping the fronts by 3psi (0.2 BAR) and see how the next 10k goes
04-27-2012, 12:55 PM | #19 |
Rep 1
Correct tyre pressure
I've been trying to "decipher" the tyre pressure sticker on my car to ensure I'm running the correct pressure, having replaced my 17" SE trim alloys with some 18" MV3 alloys and ordinary performance tyres (I've binned the run-flats!!)
My sticker is slightly different to that pictured by "urfankhaliq" but mine is an E90 saloon, not a coupe. I'm running 225 40 18 tyres on the front and 255 35 18 tyres on the rear, so I've decided to set it up 2.5 BAR front and 3.0 BAR rear. This translates as 36 PSI front and 43 PSI rear. Does anybody think this is too high? |
04-27-2012, 01:50 PM | #20 |
141
Rep 736
04-28-2012, 04:37 AM | #21 |
Lamininist
82
Rep 1,030
The attached document is a good guide to what you can run on 'normal' tyres for the vehicles axle weights etc
The last two pages are where you need to look. Yves |
05-30-2012, 03:27 AM | #22 | |
57
Rep 1,698
Is anyone else running high rear pressures? |
